Ohlins rear shock
Old Feb 24, 2010 | 04:24 AM
Rama's Avatar
Rama is on a distinguished road
Ohlins rear shock
Anyone know the product code of the shock for VTR?
And if possible, some pics of the same... i think i've found a shock, but want to be sure it's for the SH!
Thanks!
Old Feb 24, 2010 | 06:07 AM
Check the Ohlins Web site, it`s lsited there. You can also do a search on eBay, there is at least one on there, perhaps the code is listed....
Old Feb 24, 2010 | 07:43 AM
Rama's Avatar
Yes, but i'm looking for a real pics of the shock installed on a bike...
I've found a used shock and want to compare whit other real pics if possible...
Old Feb 24, 2010 | 08:56 AM
zmaniv's Avatar
It looks a lot like the stock setup but it has the adjuster and the remote res coming off of it.
Old Feb 24, 2010 | 09:23 AM
killer5280's Avatar
https://www.superhawkforum.com/forum...59&postcount=7
Old Feb 24, 2010 | 09:55 AM
Gaggenau's Avatar
Gaggenau is on a distinguished road
i have an ohlins on mine, will take a pic of it at the weekend when i get to it
Old Feb 24, 2010 | 10:10 AM
Öhlins code: S46HR1C1S
Old Feb 24, 2010 | 10:26 AM
kwad9's Avatar
kwad9 is on a distinguished road
this is only the type code, it stand for:
S - Single tube
H - Hose mounted reservoir
R1 - Adjustable rebound damping
C1 - Adjustable compression damping
S - Hose mounted hydraulic spring preload adjuster
The part number for the vtr is : HO 701
and some dimension:
Length: 346 mm
Stroke: 60 mm
Old Feb 24, 2010 | 11:02 AM
Mine is not mounted yet and I can take some more pics if you need any.
Old Feb 26, 2010 | 04:07 PM
Rama's Avatar
Good!
And now, I'm sure that's the correct shock for the VTr...
I've just installed!
Old Feb 27, 2010 | 02:35 PM
Rama's Avatar
another questions.......
Anyone have the standard set-up for compression and rebound? How many clicks from all close.... or all open...
And how adjust the preload, whit the idraulic adjuster?
Thanks for your advices...
Old Feb 27, 2010 | 03:53 PM
Well here is a link that will take you to the mounting instructions and owners manual.
http://www.ohlins.se/Our-products/Mo.../Sport/HO-701/
The base line is Reb @ 12 clicks and Comp @ 12 clicks. As for the Hyd adjuster, you measure the spring length and mount it with 15mm of preload and check to see if you can get the proper sag, if you can't dial it down enough, then remount the spring with 10mm of prelaod and try again.
Old Feb 28, 2010 | 12:51 PM
Rama's Avatar
Great job 8541Hakw!
But the 12 clicks are from the "all close" or from "all open"?
Thanks!
Old Feb 28, 2010 | 06:16 PM
Great job 8541Hakw!
Thanks!
all closed and no worries
krongsak
Jul 5, 2014 01:58 PM
Anto
May 14, 2009 03:10 AM
Randman
Apr 3, 2007 06:11 PM
CNI Dawg
Jun 3, 2006 06:03 PM
superbling
May 20, 2006 03:36 PM
