off to the doctor...
Made an appointment to have the old girl picked up by my trusted tech on Friday. On the menu for this year:
- strip engine, inspect bores ; hopefully all is good in which case a hone and re-ring is in order (otherwise, a bore job is in order and in will go the new 99mm slugs)
- inspect valves guides, replace if needed
- replace all valve seals
- refresh valve seats
- replace intake cam (currently Mori Stg 1 EX cam) with Yosh Stage 1 (additional 1 degree duration and 0.6mm lift)
- replace intake valve springs
- machining upper case for better venting
- replace flywheel (new unit is 2.6 lbs lighter than stock, courtesy of EMarquez)
- replace seals for drive shaft and shift shaft
- replace wiring harness (was getting short in the rain so hopefully this will cure that)
- lube shock linkage
- install Quickshifter (seeing as how it will be apart anyhow...)
- replace rear cowling (seeing as how it will be apart anyhow; existing one is cracked were mount screws are so picked up a pristine one from Beau and had it colour-matched - will fix old one and have it as a backup)
Hopefully this will cure the oil burning problem and net me a bit more zip along the way...
I performed another (relatively minor) mod to the airbox lid (filter-in-lid mod), raising the lid by 10mm and replacing the prior K&N VTR1000 filter element with an unmolested one... all to help it breathe better (especially with the more aggressive cams)...
should be ready just in time for riding weather to arrive....
ClevelandSuperhawkRumble
Oct 6, 2007 08:02 PM
