micron exhaust
Old May 29, 2014 | 10:38 PM
shadow623_'s Avatar
Newbie to the *****
shadow623_ is on a distinguished road
micron exhaust
does micron exhaust require tuning or any other modification if i just get slip on pipes? read alot if you put slip ons on after you have to tune it. i only plan on doing slip on exhaust and thats it
Old May 30, 2014 | 01:30 AM
jerryh's Avatar
Try it
Old May 30, 2014 | 03:44 PM
insulinboy's Avatar
To get the most out of it yes. But I have a Micron CF slip on set up on my VTR and the carbs are factory. Has plenty of get up and go.
Old May 30, 2014 | 05:27 PM
twist's Avatar
if you're gonna go to the expense of changing the exhaust you might as well tune the carburetors so the bike runs best. At least try hawks carb tune thread, it's easy and you will be glad you did it.
Old May 30, 2014 | 10:20 PM
So the answer is no, you dont at all have to, all will be fine as is. But since they flow more you will get benefit from some (re-)jetting (there is a detailed thread about it on here).
But if you are asking this question, its unlikely you are about to rip into your carbs.
A shop will charge you a lot to do the job, so wait til you're bored or want to dump the money.
Old May 31, 2014 | 07:38 AM
bzera's Avatar
bzera is on a distinguished road
I have a micron exhaust and with factory settings on the carb and pair disabled it does run a little lean. Minor tiny pop ever once in a while. Just as smokin joe said you would be fine as is.
I'm certainly happy with it sounds good.
bpw
Aug 30, 2013 12:50 PM
iracebikes
Oct 3, 2012 12:57 PM
avramd
Jun 4, 2011 08:16 AM
Blkbird
Jul 24, 2008 05:13 PM
Speed_Demon
Mar 10, 2006 01:43 PM
