View Poll Results: Would you like custom long carbon fiber velocity stacks for around $250 + shipping?
Yes
16.67%
No
30
83.33%
Voters: 36. You may not vote on this poll
Long Carbon Fiber Velocity Stacks
Good job, mick! Now where do I send the money for mine?
The reason the I4 guys like this is when the engine really starts to breathe these stacks take it to another level. That can only be great for the Superhawk because extending her haul only makes her that much more of a freight train.
I like going everywhere in low gear.
These (longer) stacks are designed to beef up the lows and mids (to the tune of 5 hp in the upper mids apparently) without any loss in top end. The ones that give a boost in top end are the shorter ones
It is more about adjusting where the power will happen in the RPM range than it is about increasing the peak number. (because it probably won't increase the peak, though it can make the power more available over a wider range of RPMs)
The stacks (the longer of the two versions offered) do NOT increase peak numbers. They were designed to boost the lows and mids WITHOUT penalizing the top end. The short ones, on the other hand, were designed to work on highly modded engines whose operating envelope is in the higher registers.
When you part arrives I will reverse engineer the stack on the CMM and then transfer that dimensional data to my 3D model I've already started so that to make it accurate of the actual part. Helps speed up the process for you guys.
While carbon would be nice, I'd take them in cast iron if I had to, lol (hell, pottery clay if I knew it would hold up....) I am REALLY looking forward to bolting a set of these onto my VTR..... (I know, most of you are probably shocked by that revelation, lol)
