View Poll Results: Would you like custom long carbon fiber velocity stacks for around $250 + shipping?
Yes
16.67%
No
30
83.33%
Voters: 36. You may not vote on this poll
Long Carbon Fiber Velocity Stacks
Old Apr 22, 2009 | 06:55 AM
FL02SupaHawk996's Avatar
Fastest Color
Just gauging interest in a possible group order for long carbon fiber velocity stacks. They would be modeled after my billet stacks and would run around $250 USD + shipping. This is the shop that would custom build them for us:
http://www.carbonpartz.net/
I installed these pictured below and got a nice gain according to my butt dyno They are rated at +2hp, but I figure they can be combined with a high flow filter such as K&N with rejetting for more...
Attached Thumbnails Long Carbon Fiber Velocity Stacks-02-09-09-billet-velocity-tunnels.jpg
Old Apr 22, 2009 | 07:02 AM
To be honest I was hoping for them to be a little cheaper but I'm in nonethless. If I may make a suggestion Rick, perhaps you should explain the benefits of using these (to justify the expense).
Old Apr 22, 2009 | 07:31 AM
If I may then. I seem to recall that these runners, developed on a flow bench and both longer than the longest OEM unit, are designed to work at low and middle rpms (as opposed to just 8K and up as would a pair of short ones). They are said to beef up the mid-range considerably to the tune of about 5 hp when dialed in (and isn`t the mid-range torque what we love so much about these engines?) without hurting top-end (compared to stock stacks) due to their ability to flow more air.
there you go....
On a personal note, I want to incorporate these into my future rebuild (along with slightly oversize custom JE pistons, in addition to my existing ported heads, Yosh cams,....)
Old Apr 22, 2009 | 07:39 AM
Fastest Color
Thanks Mikstr, I couldn't have said it better...all I know if I have them on and they make a big difference when paired with the K&N filter
Old Apr 22, 2009 | 07:46 AM
hawxter996's Avatar
ole dirty bastard
ive seen the work done by them,i will pass.
Old Apr 22, 2009 | 07:48 AM
Why is that Hawxter? He seems to have a lot of satisfied customers on the Speedzilla site....
Old Apr 22, 2009 | 08:01 AM
jbaxx's Avatar
Honducati
Using two long (factory) velocity stacks makes a noticeable improvement in low and mid range power and costs about $15 IIRC.
Old Apr 22, 2009 | 08:06 AM
Yep, I have been doing just that for years now (actually believe I am the one who introduced the idea to this forum years ago after having read about it elsewhere). These are said to be significantly better than that, however. Granted, this is not for everyone, but for those looking for that little extra, it is the next logical step.
Old Apr 22, 2009 | 08:23 AM
BeerHunter's Avatar
Slacker
If someone could make these out of a more appropriate material for this application, such as ABS plastic, and the price was around $50 then there would likely be considerable interest. I cannot justify pricey carbon fiber for use inside the air-box. Not on a street machine especially.
Old Apr 22, 2009 | 08:46 AM
hawxter996's Avatar
ole dirty bastard
i wont get into it here.
not fair to him.
just not happy with quality.
Old Apr 22, 2009 | 09:02 AM
way too much $$ for $2 worth of matting and glue
Old Apr 22, 2009 | 09:04 AM
cliby's Avatar
ok, simple question here and I'm sure its been hashed over many times, but I'm lazy today plus this topic warrants the discussion. Why did the factory design 2 different length stacks? what other changes are you making to compensate for adding the longer front stack? I do know the HRC carb kits came with slide's that were modified - but for a nonmodified airbox they only suggested replacing the front slide (guessing to slow it down, it had an bleed hole I believe).
my point is I'm guessing jetting that front carb could be trickier after changing the stack length, and any benefit might be only in the context of other changes in cams, exhaust or otherwise. Does anyone have data on the benefits of simply replacing the shorter stack and seeing HP and not messing up low speed jetting?
Old Apr 22, 2009 | 09:44 AM
Fastest Color
Bill, I have them installed with a K&N filter with the plastic cross member installed that I cut off an OEM filter. The bike runs like I stole it over 4K rpm so I can assure you these babies work well 4K-redline w/o rejet, but she studders more than usual below 4K...That should speak to your question that the long stack in front will need some carb tunning on the slow jetting, but that said, it runs pretty good below 4K so I figure it's not that far off with my current jetting for a full Erion race exhaust system...
Old Apr 23, 2009 | 08:26 AM
Hi again Rick,
just curious as to why the price is so steep. I found a thread on Speedzilla where he is making a pitch for his RC51 carbon stacks at "$120-ish" (http://www.speedzilla.com/forums/rc5...mpet-pics.html). In yet another he mentions $200 for said stacks. Just curious as to why the premium for the VTR units (maybe we could get more peope to buy in if they were a bit cheaper)...
cheers
Old Apr 23, 2009 | 08:30 AM
Fastest Color
Mikstr, that's the price he gave me Guess we could look elsewhere...you think Truck could turn them outta aluminum?
Old Apr 23, 2009 | 08:36 AM
that could work too.....
Old Apr 23, 2009 | 08:37 AM
Truckinduc's Avatar
I have plans to make some out of fiberglass. It should be pretty easy and pretty cheap.
What are the length on those stacks?
Fastest Color
I'll PM him and let you know what he says ASAP!
Old Apr 23, 2009 | 08:38 AM
Fastest Color
There he is! I'll get you measurements tonight
Old Apr 23, 2009 | 08:43 AM
If I may, I would think the critical measurements are the overall length, taper, and bell-mouth radius (all the things are affect airflow). AS these were designed on a flow-bench, I think it`s critical to get them virtually identical.
Old Apr 23, 2009 | 08:45 AM
Fastest Color
Mikstr, you want those measurements to the 0.00001 mm?
LOL
Old Apr 23, 2009 | 08:48 AM
.001 mm should be acceptable
thanks again for your help Rick. I realize you have nothing to gain from this (heck, you already have a set), appreciate your selflessness!
Old Apr 23, 2009 | 08:50 AM
Fastest Color
No prob
Old Apr 23, 2009 | 09:49 AM
Stumpy's Avatar
I would love a set if the $ amount is more reasonable. Will keep watching this thanks guys for all your help.
Old Apr 23, 2009 | 10:02 AM
Erik S.'s Avatar
Rick, thanks for sharing, as mikstr said, very selfless.
I'm with Stumpy, more reasonable and I'm in.
Old Apr 23, 2009 | 12:34 PM
andy9743's Avatar
id also be interested, but i can't justify the $ for c/f that i can't see...hell my bike is flat black these are more expensive then my paint job!
Old Apr 23, 2009 | 12:43 PM
If I may comment, as this scheme was basically my idea, the CF is not the important part of this project. I merely suggested it as the chap who was initially contacted made some simlar ones for the RC51, proving it could be done for the VTR. To be honest, I personally do not care much what material they are made from (so long as they are durable). The key ingredient is to have stacks that match the dimensions of Rick`s and bolt up properly. Anyone with other suggestions please speak up. The cheaper we can get them, the better it is for all of us.
Old Apr 23, 2009 | 02:23 PM
cliby's Avatar
Rick I must have missed a description somewhere. are the stacks you have merely billet reproductions of the stock longer stack? or different shape/size?
Old Apr 23, 2009 | 03:32 PM
FTMS's Avatar
How well will these work with a stock motor? I can defiantly see the reason for them with a motor that has cams or other mods that need increased air flow.
Old Apr 23, 2009 | 05:28 PM
these stacks are designed for stock or non-race engines (the same chap builds short stacks for highly modified high-rpm applications). Here is info I received in an e-mail from the guy who developed them:
"The long series are designed to improve the torque of the engine lower mid and mid to mid upper RPM range, but will not lift the Max top end HP. They simply bolt on in place of the original stacks. Both front and rear stacks are the same length in the long series and are about 20% longer than the longest original velocity stack. You will most likely have to drop the jet sizes slightly with these stacks."
