lighter wheels
Old Sep 26, 2009 | 05:08 AM
uchi's Avatar
lighter wheels
ive decided to mod the bike over the winter and i wanna put ona lighter set of wheels. that being said aftermarkrets are worth what the bike is to me so i wont go that route. what im wondering is what stock wheel will fit the bit without having to change anything and will drop some weight?
Old Sep 26, 2009 | 06:58 AM
Kendrick's Avatar
The Hypno-Toad
None will drop weight and aftermarkets are too damn expensive. Spend the money on a different mod IMHO.
Old Sep 26, 2009 | 07:48 AM
uchi's Avatar
yeah thats what i figured. aftermarkets are way too expensive for the minimal gains. wonder if i can put a small nitrous shot on the bike and still keep it safe
Old Sep 26, 2009 | 08:22 AM
zmaniv's Avatar
Minimal gains?
reducing unsprung reciprocating mass is the best bang for the buck mod possible.
Old Sep 26, 2009 | 08:25 AM
cliby's Avatar
there are some swaps that work and do lighten things up. And a few pounds in the wheels is much more noticeable than anywhere else, or a few hp.
you'll have to search to find out which, lots of past posts on it - some of the earlier 900RR series wheels I believe. The SH wheels are not particularly light.
Old Sep 26, 2009 | 08:29 AM
drew_c14's Avatar
Originally Posted by zmaniv
Minimal gains?
+1
this is one of the best ways to improve performance that there is
Old Sep 26, 2009 | 08:51 AM
uchi's Avatar
sorry i worded that wrong, i realise that unsprung weight is probably thr best bang for the buck, improves braking acceleration and corner, but for the money a set of rims are worth im sure i could get the same results with increases everywhere else. speaking of unsprung weight, does it apply to the front sprocket aswell? im sure the few grams or ounces a sprocket can be made lighter woldnt really make that big of a difference
Old Sep 26, 2009 | 09:02 AM
zmaniv's Avatar
Yes however the further from the center of the moment the greater the results.
say if you are doing the flywheel removing a 1/4 inch from the radius will give better results than removing the same ammount of weight from the flat surface
Old Sep 26, 2009 | 09:08 AM
uchi's Avatar
true enough. what are my flywheel options for the vtr? and what kind of torque loss can be expected with the top end gains?
Old Sep 27, 2009 | 10:21 PM
Just_Nick's Avatar
Who are you?
You don't lose torque, you just get faster revs.
And if you can manage to mount a RC51 rear wheel, which I believe is lighter, you will be reducing unsprung mass and rotating resistance.
Old Sep 27, 2009 | 10:34 PM
autoteach's Avatar
hmmmm,
wheels, new-$2000
that is expensive, but
high comp pistons-$350/1
head gaskets-$37/1
porting-DIY or pay $$$
Lighten flywheel-DIY or pay $200-300
520 chain conversion- $150-180
Cams- $500-1000
So, after you get done f-ing around with the engine all winter and most of $2000 doing the work yourself, you will have a snappier bike, higher top speed, and your handling will not have changed by much, and your braking will be the same.
Do the wheels and----your bike will accelerate faster, probably won't gain much on the top end, will turn quicker, and slow quicker, and the bike will be lighter. For $2000 you can have your tires mounted and on the bike in a week or two.
I know it is your pick, but think it through.
Old Sep 28, 2009 | 04:48 AM
JamieDaugherty's Avatar
I've swapped 900RR rear and F3 front to my bike a few times. The ol' "one in the right hand, one in the left" way of measuring says that you can't tell a difference. Unfortunately you have to go the aftermarket route I think. Man would love a set of carbon fiber wheels....
Old Sep 28, 2009 | 08:46 AM
cliby's Avatar
hmmmm,
wheels, new-$2000
head gaskets-$37/1
Cams- $500-1000
good summary. not to mention dyno time and jetting woes
Old Sep 28, 2009 | 10:20 AM
Just_Nick's Avatar
Who are you?
Hell, at that point you might as well get a rc51 and some riser clip-ons, and a different seat.
Old Sep 28, 2009 | 11:51 AM
I think somebody waaay back when put them on a scale and the verdict was that the 900RR rear was a smidgen lighter and the F3 front was a smidgen heavier...
I can say for sure though that the CBR 1000RR wheels I'm running is substantially lighter about a Kg in front and close to 2 Kg in the rear...
But for that you need a special "adapter"... So it's probably cheaper with aftermarket wheels...
Old Sep 28, 2009 | 12:57 PM
SlowHAWK's Avatar
hmmmm,
wheels, new-$2000
head gaskets-$37/1
Cams- $500-1000
Plus... you can take the wheels off and sell them seperate of the bike which will probably be worth less than the wheels after another year or two!!!!
J.
Old Sep 28, 2009 | 01:37 PM
uchi's Avatar
thats the thing too, a set of aftermarket wheels are gonna cost me more than the bike is worth to me. id rather re gear do my jet kit filter see if theres anything else i can do cheaply swap out the front suspension as it needs it anyways and do a front brake upgrade and be set and likely be well under the cost of just the wheels.
Old Sep 28, 2009 | 02:39 PM
If you are going to do all that... Why not swap out the front for CBR gear... Then you have a CBR wheel there... And pick anyone of them 929/954RR or 1000RR and they are lighter than stock VTR by far... And you get stiffer suspension and beefier brakes as a bonus... And if you pick and choose your buys you can do that real cheap...
Old Sep 28, 2009 | 04:39 PM
uchi's Avatar
Interesting. What's a comete front like that worth and how much work is it to swap in?
Old Sep 28, 2009 | 05:29 PM
https://www.superhawkforum.com/forum...ad.php?t=20222
Other than that, search "front end swap" or "fork swap" and you get loads of info...
Have a look at my gallery, just click the image in my sig...
Old Sep 28, 2009 | 05:38 PM
Kendrick's Avatar
The Hypno-Toad
I don't know, after all of this discussion I'm retracting my initial statement and thinking about aftermarket wheels. Thanks guys, now I might have to spend more money...
Old Sep 29, 2009 | 06:15 PM
shayne's Avatar
Lighter wheels are a distinct performance advantage, in acceleration, braking, and handling.
And they look as sexy as a Playboy centrefold.
Old Sep 29, 2009 | 07:19 PM
uchi's Avatar
Yup those are sexy. What are they worth? And do you find an advantage with those rotors?
Old Sep 29, 2009 | 10:12 PM
FlamFlamMan's Avatar
FlamFlamMan is on a distinguished road
I think the whole package gives him an advantage with the ladies
Old Sep 30, 2009 | 03:20 AM
Let's not forget an important point here fellas - lighter wheels are not nearly as strong as stock wheels. They are known to bend like crazy on very small hits. Life is not perfect!
Old Sep 30, 2009 | 04:13 AM
uchi's Avatar
I've got a gf I'm stuck with so the only person I'm trying to impress is myself with my thin chickenstrips. Lol.
Old Sep 30, 2009 | 06:32 AM
JDRiderCoach's Avatar
JDRiderCoach is on a distinguished road
Adding HP to your engine is the last mod you want to make AFTER you've dialed in the suspension, brakes AND improved your riding skill. Take the money you'd spend on mods and go to a high perfomance riding school like Keith Code or something. All the go fast goodies in the world don't help if you ride like a tool. You'd be amazed at what the SH can do with 0 mods and a good rider. Case in point, I rountinely make local squids disappear in my rear view when we hit the twisties, even though my Hawk is only slightly moded. They'll be on tricked out R1s and such and I'll still smoke 'em. Also I'm a big proponent of lighter wheels, and no you don't have to compromise strength or spend $3K on Marchesinis. They dramatically improve turn in, acceleration, etc. Check out these forged aluminum wheels for just under $1800. They can be had for $1500 on their Racer Support program(if you can prove you race).
http://forged-wheel.com/
I have a set on my Hayabusa and they are SICK.
Old Sep 30, 2009 | 07:06 AM
LineArrayNut's Avatar
I could ride in
i don't see a specific app. for superhawks. you know they'll fit? and with what mods necessary?
Old Sep 30, 2009 | 07:13 AM
It's true the good stuff is expensive...but there's no need to pay retail for new stuff if you're patient and look around. Yeah $5k BST's will still bring $3500 used on ebay, but around 1k can get you a used set of rc51 marchesinis (that you can always resell later and get your $ back), and I've seen a couple used sets of direct bolt on aftermarket wheels for a superhawk go for between $400-$600 on ebay. Also be creative and remember other Honda wheels fit the superhawk so you can look for used stuff off 900rr's and F3's as well. I've also seen several bikes for sale over the years, including a few racebikes, that look like they drove thru the aftermarket with a magnet on them. If you can buy a bike like that for a good price you can usually take what you want off it and resell it and end up getting all your goodies for cheap.
Old Sep 30, 2009 | 07:18 AM
While Carrozzeria does not make a set specific to the Hawk, they can be adapted. Call their Sales guy Adam, he can set you up. One compromise you have to make is switching to a Kawasaki bolt pattern for the sprocket. So if you get a set, you'll have to get a rear sprocket too.
