Increase compression ratio
Old Apr 21, 2005 | 08:39 AM
EMetz996's Avatar
EMetz996
Has anyone machined their heads down as little as .010 to increase the compression ratio?
The VTR's are on the low side around 9.6, and .010 to .020 machined off the mating surface would bump it a little. I've done this to large bore ATV's with great success, but never a motorcycle.
Old Apr 21, 2005 | 09:10 PM
RymerC's Avatar
RymerC
I'm curious as to whether we could just use a thinner head gasket?
Old Apr 22, 2005 | 06:55 AM
EMetz996's Avatar
EMetz996
Re: Increase compression ratio
Generally speaking, as of the last 10 years or so I have not seen a head gasket thinner than .020 except on Briggs motors. So going thinner isnt an option today on most engines, but it used to be!
Old Apr 22, 2005 | 10:04 AM
RymerC's Avatar
RymerC
is that what the stock gasket is? thanks honda!
looks like milling is the only alternative to pistons... Unless you want to play with cam timing
barncat
Aug 20, 2012 07:46 AM
Little_Horse
Feb 14, 2012 03:32 PM
Karbon
Oct 7, 2009 07:04 PM
Red_Liner740
Aug 18, 2009 05:51 PM
mikstr
May 6, 2006 04:02 AM
