Hossack conversion.
Old Jun 15, 2010 | 02:03 PM
heng47's Avatar
heng47 is on a distinguished road
Hossack conversion.
So, anyone have any advice on what kind of shock I should use?
I figured I should use the same stuff back and front. So either I use the stock shock infront, or I get a new pair for both. Or am I totally out of my mind?
Quick note, it's a school project and I'm building it frame-up.
Old Jun 15, 2010 | 02:47 PM
So something like this: https://www.superhawkforum.com/forum...ad.php?t=16235
I don't know why you'd want the exact same shock on both ends, the weight isn't exactly 50/50, and the loads put on each end are different.. Plus the VTR shock in stock form isn't that great.
Old Jun 15, 2010 | 03:12 PM
heng47's Avatar
Well, because it's cheap.
Old Jun 15, 2010 | 03:26 PM
True, but so are F4i (and other) shocks that offer more adjust-ability
Old Jun 15, 2010 | 04:08 PM
bjorn toulouse's Avatar
Destructive Tester
Yes, you are out of your mind, but in a good way!!
Myself, I would be scrounging M/C salvage yards for a shock for the front end. Something shorter than a SuperHawk shock would be easier to fabricate around.
Here's a few links you might find useful:
Tony Foale's site: http://www.tonyfoale.com/
Tony knows FFEs!
Michael Moore's site: http://eurospares.com/
A very active FFE/chassis fabrication mailing list.
Works Performance application guide...this list has the OAL of all the various shocks by make and model:
http://www.worksperformance.com/pdf/...ide/street.pdf
Good luck with your project, and post up pics as your build progresses.
Rex
Old Jun 15, 2010 | 05:01 PM
heng47's Avatar
Interesting, didn't think of that. Thanks!
Just checked yahoo auctions japan, not that very many and quite expensive. May have to resort to ebay.
Old Jun 15, 2010 | 05:12 PM
On eBay the f4i shocks go for ~$50... More than that and you are cheating yourself...
Old Jun 15, 2010 | 07:05 PM
heng47's Avatar
I just spent the past few hours going through that 5 pages of discussion that tweety and JD and others had about the OEM showa and I just had to ask, wouldn't it be simpler to attach a mount onto the frame to lower the mounting point of the shock rather than disassemble the shock and fabbing a new clevis?
Maybe I should've asked over there but didn't want to pull up a year old thread.
I'm asking because since I'm building the frame and swingarm, I could just lower the mounting point to fit the cbr shock. If so, I could just use a shock off a cbr 1000, may have to check if the spring rate matches.
Old Jun 16, 2010 | 01:31 AM
afm528's Avatar
large member
afm528 is on a distinguished road
Cool project, good luck. Keep us posted on your progress.
Old Jun 16, 2010 | 03:45 AM
Uh... yeah... And that would be the reason I did just that...
My upper mount is adjustable, not the shock... But it lets me set ride height...
Old Jun 16, 2010 | 04:30 AM
heng47's Avatar
But didn't you also had your clevis redone?
The red **** parts.
Old Jun 16, 2010 | 04:32 AM
Nope... My CBR F4i shock is re-worked on the inside but stock on the outside...
Old Jun 16, 2010 | 04:33 AM
Old Jun 16, 2010 | 07:32 AM
heng47's Avatar
Great, that means I can use the shock in the firestorm chassis once my project is over!
Old Jun 16, 2010 | 08:27 AM
Um... the spring rate might be a bit on the soft side but yeah...
Hawkrider
May 21, 2008 11:00 PM
SnapAttack
Sep 12, 2007 07:11 PM
MarineHawk
Apr 26, 2007 10:28 AM
EngineNoO9
Jan 23, 2007 09:21 PM
Rassie
Jan 6, 2007 01:22 PM
