High Comp. Pistons
Old Jun 10, 2008 | 08:13 AM
Pimpsterbim1's Avatar
JAMES
High Comp. Pistons
I know the stock hawk has fairly low compression... Where can i get a high comp set a good price??? Will this make a noticable difference???
thanks..
Old Jun 10, 2008 | 09:15 AM
killer5280's Avatar
It will make a difference, but it needs to be done with other modifications (porting, cams, full exhaust system) to really get the best out of the engine.
I have high compression pistons (but not the other mods) and I can't definitively say it was worth the expense or effort, and now my VTR won't run on regular gas.
Installing the pistons was something I was determined to do; nothing would have dissuaded me. Eventually, I will do cams and exhaust.
Shortening the gearing gave a much more noticeable kick in the pants for a whole lot less time and money.
Old Jun 10, 2008 | 02:02 PM
PUSHrod's Avatar
My bike has Moriwaki pistons and cams from a kit off of e-Bay. Engine performance is always a balancing act, you have to re-jet the carbs to get the potential from the cams and pistons and at the back end, you need free flowing pipes in order not to constipate your effort upstream.....then there's the question of the stock frame and suspension being able to handle the enhancements.
The dyno said 65 ft lbs and 126 hp on hi-test. Because of the PITA factor, I think I would have gone to a RVT and just been done with it in retrospect.
Old Jun 10, 2008 | 02:27 PM
drew_c14's Avatar
126...wow, I don't think I've ever seen a VTR that high
Old Jun 10, 2008 | 02:44 PM
LineArrayNut's Avatar
I could ride in
there's a guy in italy that's up there with that number
CruxGNZ
Mar 23, 2016 10:21 AM
VTaRse
Feb 1, 2014 06:05 AM
grnell
Nov 13, 2013 02:23 AM
mboe794
May 2, 2010 04:30 PM
DameDiggler
Mar 25, 2005 01:37 PM
