GEARING QUESTION
Old Jan 30, 2009 | 06:13 AM
ericb269's Avatar
kneeedragger
ericb269 is on a distinguished road
GEARING QUESTION
I was in the process of buying a 520 convesion when the salesman at kneedraggers said that the best gearing for my hawk is to go one down in the front and 3 up in the rear??? What will my top speed be if I do this. He told me that it would change my ration to 2.87 but I have no idea how to determine top speed.
Old Jan 30, 2009 | 06:15 AM
drew_c14's Avatar
there is a spreadsheet floating around here somewhere....
I'll check my computer, but try doing a search for it on the site.
Old Jan 30, 2009 | 06:16 AM
drew_c14's Avatar
https://www.superhawkforum.com/forum...ht=spreadsheet
try this
I'm down 1 in the front, stock in the rear, and haven't seen above 150. A combination of not enough road and not enough ***** I guess. Plus I can't imagine it will push much past that anyway.
Old Jan 30, 2009 | 06:19 AM
trinc's Avatar
a bunch of us run -1/+2. it's good for the moutain roads but those that do a lot of highway miles don't like the rpm increase. so it depends on how/where you ride. if you do change the gearing you'll need a speedohealer to correct for the gearing change.
looks like i stopped just in time : )
tim
Old Jan 30, 2009 | 06:30 AM
Drop one in the front and leave it. still usable on the slab to get to where you need to, but lowers the gearing enough to make exiting corners a bunch more fun.
Top speed?? Well unless it's modified motor making a bunch more HP then stock,, My speedohealer corrected speedometer and GPS say, 148 is all it's gona do give or take some wind with the 15/41 gearing.. Your results will differ
I may try the added 43 in back, just to do it.. but I do not imagine I'll like it much... To many HY miles at 70~80 MPH between turns in TX
Old Jan 30, 2009 | 06:38 AM
ericb269's Avatar
kneeedragger
man this forum rocks thanxs for all your help guys. I like long trips on my bike so I dont want to jack up my gearing I will drop one in the front and go from there.
Old Jan 30, 2009 | 06:56 AM
I have tried many combos over the years (16/43, 15/41, 15/43, 15/42). I am currrently running 15/42 but will be going back to 15/43 next chain and sprocket change. I do a lot of highway miles and do not find the last two set-ups (in the list above) to be disruptive.
cheers
Old Jan 30, 2009 | 07:50 AM
Little_Horse's Avatar
2nd mouse gets the cheese
tim
pretty trick Tim with the whole 666 thing there. Im surprised your bike didn't explode.
Old Jan 30, 2009 | 08:38 AM
FL02SupaHawk996's Avatar
Fastest Color
I've run the 15/43 too and would recommend 16/43 which probably feels a lot like 15/42 others are running...
The 15/43 is just too buzzy for me...RC
super duper hawk
Oct 1, 2009 04:25 PM
YTKinWI
Aug 5, 2009 06:16 PM
shayne
Oct 23, 2008 12:16 PM
wyldryce
May 16, 2007 07:59 PM
Otto Man
Mar 27, 2007 09:49 AM
