Fork Springs - Sonic vs. Racetech?
Old Aug 29, 2008 | 12:41 PM
Sablotny's Avatar
ReNoob
Sablotny is on a distinguished road
I'm still dealing with a lump of a Visa bill on the new bike and gear, but I feel I need to address the wimpy fork springs ASAP. I'm going to try 0.90kg/mm springs first, and then plan on a revalving later (unless someone here convinces me not to). I see Sonic springs are $79 and Racetech $119. Anybody have experience with Sonic? Any reason to spend $40 more? Thanks for any & all 4-1-1.
Old Aug 30, 2008 | 06:30 AM
motojoe's Avatar
Sexual Daredevil
I have Racetech in mine. Makes a huge difference over stock. I have no experience with Sonic.
Old Aug 30, 2008 | 06:56 AM
superbling's Avatar
I've only had racetech's in the past and they work but I think you're paying for their name/reputation which they've earned. I'd go with the sonics if it were me. If you'll be adding the racetech internals later, I'd order the spring rate they call for if it's different from sonics suggestion.
Do a fluid change/cleaning while you're at it. They will need it badly.
Old Aug 30, 2008 | 07:24 AM
nnjhawk02's Avatar
Ditto
But if ur in there - U might as well re-valve it at same time + fluids
Do it right the 1st time
Old Aug 30, 2008 | 08:07 AM
trinc's Avatar
i have sonics & recommend them. they dyno test every spring just like all the other players & they're a bit cheaper....
look at my track pics & you'll see i push my 'hawk about as hard as you can.
i still have stock valves and ran 7w w/ 140mm air gap, rebound was just about max'd with .95g springs ( me :180lbs )
edit: for the fall i'm trying 10w w/ 155mm gap.
been in my forks for 2 yrs.
tim
Old Aug 30, 2008 | 08:55 AM
killer5280's Avatar
I have Sonics, too. Same quality spring as Racetech I think.
Old Aug 30, 2008 | 06:17 PM
Sablotny's Avatar
ReNoob
Thanks all. I took a look at the Honda shop manual and saw you have to take the forks off to do the work I'm new to bikes with motors on them, so I think I'll have a shop do it for me. I was hoping it was a simple slide out/in from the top. Really not liking the queasy front end, did a ride over country roads today and bottomed out several times just going over asphalt humps and paving transitions.
Attached Thumbnails Fork Springs  - Sonic vs. Racetech?-schussing-geysers-custom-.jpg
Old Sep 1, 2008 | 06:21 AM
JamieDaugherty's Avatar
Yes, the springs can be removed with the forks on the bike.
For my weight I'm supposed to have 1.0 springs. I've got CBR954 forks on my bike now, but when I was running the stock I never bottomed them out, at least not hard enough to know. It almost sounds like something is up with your damping more so than the springs. How much do you weigh? I'm wondering - if you are bottoming out that bad maybe 0.9's won't be enough.
Old Sep 1, 2008 | 04:25 PM
Sablotny's Avatar
ReNoob
I'm 195# without gear, the RaceTech calculator says I should be using 0.90. The PO was equivalent to my size and I don't think touched the forks.
I bottomed out on some very low speed transitions from pavement to gravel, nothing at high speed. Think I'll try the springs first, and if I get into the motorcycle thing hard core I'll do a fork swap later.
tfsttr
Apr 10, 2010 07:27 AM
divingindaytona
Oct 7, 2009 06:29 PM
Hawkrider
Jul 4, 2009 08:36 PM
roisman
Mar 26, 2008 07:49 PM
CNI Dawg
Jun 6, 2006 07:23 PM
