Fork;Springs OK or re-valve needed?
I have RT springs valves (not installed yet) For city street use will the springs & oil level be an improvement? I have been told that revalving the honda vaves(by someone good) is the way to go. I live in NYC & ride daily so I cant send them somewhere for valving. I can do the springs tho. Are 90kg springs too heavy for the street?(200# rider & sometimes 2 up). Any help greatly appreciated.
Just so you know...
When Greg did mine. I shipped them UPS Ground to him, he had them the next day. He had them complete in one day, and when he shipped them back, I had them next day also...
Now mine where gone longer as I shipped mine out before he had the springs recieved yet, however if you wanted to have him revalve your's, I would imagine if you work out the time ahead of time with him, you could have them back in 3-4 day's total...
just a thought
just a thought
What Josh said....
Or you could ride up here on a weekend and I'll revalve them while you watch! It takes about 5 hours total.
.90kg/mm springs will overpower your stock rebound and compression damping will still not be correct. I highly suggest a revalve.
That depends on your weight. I was running a 1.05 Ohlins spring at one point. I brake HARD! The spring rate is chosen to match the weight of you and your bike so that you can attain proper laden and unladen sag values.
I gotta tell you man... I hated to have the bike down any longer since it had already been down because of my crash... But I am glad I went ahead and had Greg just do it all, and do it right...
If you've dug into it enough to have went ahead and resprung, why not go ahead and just have him revalve them for you...
I was very happy with the results from Greg, and he worked fast... Was worth the money by far, and outside of a fork swap that I'm sure I'll never do, I'm confident that the bike is right... sounds like your half way there, and since your in the same state, shipping times are quick, shipping prices are low, and in all honestly, Greg is so close to Albany area anyway, it is very doable to just take the ride up and get them done and set up for good..
just my 47 cents....
josh
PS.. Greg, i still get that advertising cut right? lol... just kidding...
josh
The PO on my bike says he put Race Tech gold valves in but kept the stock springs. I can't compare to a stock ride but to me it feels like it bottoms out way too easy (eg. when pulling into a driveway at about 5-10mph and hitting a 1 inch lip) unless I have the preload set to 2 lines or less. Then the ride is preetty harsh. Does that sound normal for a 195# rider? I have no idea what weight of fork oil is in there or how much. Guess I'll just have to drain it and refill to be sure. Might as well upgrade the springs while in there.
Moto Man;
The original equipment fork springs suck for everybody. I had the same problem pulling in the driveway or hitting a pothole. I put a zip tie around one fork tube, shoved it down against the slider, and went for a normal around town surface street ride. When I stopped the zip tie was shoved up against the lower triple clamp. And I weigh almost 50 lbs. less than you. Proper weight fork springs for the VTR were the best $100 I ever spent on a bike.
I see that racetech has a chart that will select the spring rate determined by weight . That is probably close unless your 2up or very aggressive.
The oil flow valves is what I know flow too slow and cause compression lock.
What is the best way to increase flow with out becoming a pogo stick?
Lowell, I got your PM and replied. The stock valves themselves are okay, particularly with a lighter oil. The problem with using a lighter oil is that the stock shimstacks cannot provide enough damping to properly control fork motion. That's why the revalve is required. With a heavier fork oil the damping is okay but then you get "hydraulic lock" on large bumps (sometimes combined with braking).
Also, with a higher spring rate, a higher force is required for a given suspension velocity. Therefore, a higher damping rate is also required at that velociy to control the force.
I agree with Greg. No valve modifications required with lighter oil, unless you know what it is you are trying to modify. The stock valves are very good.
Race Tech valves are vastly different than the stock valves. To install Gold Valves without significant shim stack modifications would likely result in far too little high-speed compression damping. With the porting in Gold Valves, all of the high-speed damping must be controlled with the stack. They do not transition to orifice damping.
The CBR1000 fork w/954 triples will keep the lock. Just a couple washers and you're good to go. To be honest, I only lock with the wheel turned left. I haven't tried to the right.
No, you are not understanding what we are saying.
A heavier spring combined with a lighter oil will throw your rebound damping out the window. It will be a pogo stick.
A heavier spring with heavier oil will allow rebound damping to be sufficient for the higher return spring force, but then you will be much closer to orifice flow (hydraulic lock) on compression to the point that it will be dangerous.
The limit for aftermarket springs with stock valving and oil is about .80kg/mm. That equates to about a 150# rider on the street. Anything heavier than that and you should revalve.
I'm not trying to sell anything here. I'm telling you the proper way to do this.
I bought a stock CBR spring thinking it was .88kg. I saw that on the racetech website. Their spring calc said I'd be in the .89kg range so stock was closest. Now ya' got me wondering if I gotta start eatin more.
You can ride the bike with stock suspension, just don't ride it fast!
Set your sag and rebound damping, front and rear for the time being.
If you insist on not riding it with stock suspension, with the RC51 fork swap you'll probably have the bike down for a while. It takes a while to collect all those parts, the clip-ons being the biggest hurdle.
This a great thread! One more question for you guys with the gift of deep suspension knowledge. Since I (supposedly) already have gold valves I should be able to run heavier oil once I switch the springs and should also set the stock shim stacks to ??? to control high speed dampning?
Greg's shim stack should keep you away from the region where the Gold Valves will "blow off" (meaning the damping curve goes horizontal). He may also have something that is designed for Gold Valves specifically. I very much doubt he'll just publish his stack. And the shim kit is about $200. My recommendation is to have him do the work, because he's done enough research and testing to know what works (and no, I don't work for him).
This should keep you away from having to care what valve you have, for most situations. Then you can run a lighter oil and have better control over the low speed region. The very high-speed damping, such as when you hit a big bump when hard on the brakes, or under heavy cornering loads may never be as well handled with Gold Valves. But the jury is out on that one. Some people swear by them. Others won't use them.
If you are someone who does get into a situation where the stock valves ramp up too quickly (on a particular section of road or track) after taking these first tuning steps, then you can increase the orifice size in the valve bodies. But I don't believe that would be recommeded as a first step.
