Originally Posted by dickard37
(Post 273348)
I'm really interested in doing this MOD but I really would like to see some pics posted as to how they look and how the wires were connected. If someone who has done this MOD and who does have some pics could you post them with a nice li'l write up....please and thank you
In the knowledge base Titled Click ME>>> Coil on Cap MOD <<<Click ME Or a search using +coil +cap +mod https://www.superhawkforum.com/forum...earchid=621336 Or +coil +mod https://www.superhawkforum.com/forum...earchid=621338 |
(Post 273363)
(Post 273392)
Thank you very much. Just what i was looking for :D
Now I don't know how many of you have ever seen or heard a "raped ape" run, I know I havn't, so I'm just making an estimated guess here....... I swapped out the old coils and put in the CBR 600 stick coils, fired her up took a ride. Now let me tell ya, if a "raped ape" runs anything like the way the hawk ran after the swap then they are DAMN fast and DAMN strong lmao. She ran so much smoother and actually seemed to have gained some power but without a dyno idk all I can say is that there was a definate improvement. And just like the rest of the guys said the swap was VERY easy. I love this forum hehe |
I'm a god at resurrecting old threads. So... with the "stick" coils, I bypass the big bulky cylinder thing? I'm assuming that whatever it does is now in the plug part... And
I'm just making sure I got this right. I found the thread w/pics: https://www.superhawkforum.com/forum...ad.php?t=23004 It just seems too good to be true to not have to worry about cylinder mcgee and the ugliness that it brings. My coils are shot so may as well do this mod while I'm at it... |
Originally Posted by 7moore7
(Post 291265)
Any estimate as to how much weight??
0.8 lb, as weighed on my digital scale.....
Something to think about at some point. Saves me from having to diet:)
If all bikes experience a 2 HP increase like Tweety's, this mod would be cheap. |
Originally Posted by D VTR RIDER
(Post 291313)
I would highly suggest doing this mod, it's quick, easy, and cost effective way to replace worn out coils/plug wires and restore some lost HP.
(Post 268892)
Actually pretty close, but not completely correct Eric... The CBR1000RR coils will fit, but they are longer and will be a PITA to get in there... And they will probably require you to seal a gap with some O-ring or electricians tape...
The CBR 600RR coils are the same electrically but a bit shorter and a nicer fit... Less work and no need to seal anything... |
(Post 291774)
I found a set of 01-03 CBR 600F4I CBR600F4I IGNITION COILS (4) for a very reasonable price. To your knowledge, will the 01-03 coils fit?
No difference really, just a few hundred parts that aren't the same, and about two dozen that are... Mostly washers, bolts, hoseclips and other miscellaneous... Something that takes me 30 seconds to find out, or merely verify since I have done it before researching other parts... Should be just as easily for you... Most of it can be done by searching Ron Ayers... Now, how the *beepity beep* should I know if those fit? I specificly mentioned CBR 600RR, not the F4i, you quoted it, and it takes me 30 seconds to verify that the partno doesn't cross reference... Ie, I wouldn't know... I do however know about the CBR 1000RR and CBR 600RR as I have held both in my hand... Now, I realise I'm kind of taking this out on you, and that it's not completely fair, since you are just one amongst many... But I do find it highly annoying that people around here have a serious problem with either reading and understanding what they read, or are too lazy to do a any smidgen of research on their own... Considering your normal grasp of the language, I doubt that's the problem, so the conclusion would then be that you are lazy... Oh, BTW... If you want to make me really pissed of, try contradicting that... However, since I'm not a complete asshole, just easily annoyed, I'll give you some clues... Check the service manual for the electrical specs on the coils/ignition for the various bikes, including the sparkplugs and then crossreference the data... Then try to check actual images as best as possible... That should give you a good idea if it's probable that the coils will work... Oh... And BTW 2... I apologise for the fact that you get to take the full blow of my annoyance, you aren't the real target, or merely partly the target... That do not however change the fact that I still think you where being lazy... Or the fact that I happen to like you, and your contribution on the forum... Cya... |
(Post 291783)
Potato, potato ? Or CBR 600RR, CBR 600F4i... Is that what you mean?
(Post 291774)
Look up a few post and you'll see a link to my post on the topic. |
Use the Part fiche. Are they the same part number? Then it will work.
(Post 291783)
(Post 291798)
Sorry dont know I used CBR1000 coils and they worked GREAT.. NO CBR coil has the perferct fit for sealing to a VTR head... that I have seen,, so no mater what you'll need some modification.
(Post 291805)
:popcorn:
I just have fit's of bad temper, but I generally like him... ;) |
(Post 291874)
You know, I don't think you'll get a fight to watch... D VTR RIDER might not like me right now, judging by his short tone, but it doesn't seem like he wants to fight... And neither do I... ;)
I just have fit's of bad temper, but I generally like him... ;) Gee, u genlike me too? Your Spock side lost out. It can happen when your part Vulcan. I find this intriguing Like creating a cross-reference for DIC (Direct Ignition "Stick" Coils) http://www.densoaftermarket.com/cata....php?part=igco or finding cute sites like this http://www.motorcyclespecs.co.za/mod...a_vtr1000f.htm |
