cbr 600RR fork swap possible?
Old 11-15-2009, 10:59 PM
Has anyone tried this? I have read a ton of stuff on here for 1000RR swaps but why not these? Help me out if you know. Thanks
smokinjoe73 is offline
Old 11-15-2009, 11:06 PM
Who are you?
Just_Nick's Avatar
What year?
Call All ***** and see if they make bearings which will fit the CBR triple shaft and SH head.
Just_Nick is offline
Old 11-15-2009, 11:35 PM
I've lightly set one up since they use the same bearings. The triple works out waaay better that the RC51/954RR triple. It goes from lock to lock without coming close to the upper radiator hose, although you'd have to grind the steering stops down a bit to get the full range... but I still don't think it would hit the hose. As for the length, they are just a tad short, probably less than a half inch, but I'm sure that would be picked up in the decreased triple offset. Of course with the weight difference, springs and shim stack changes are in your future. Also, a nice handlebar setup would be hard to come by since they are 48mm
inderocker is offline
Old 11-16-2009, 02:18 AM
I think the main reason is the lighter springs/valves in them... You basicly need to rebuild them to cope with rider + the weight of the VTR...
Tweety is offline
Old 11-16-2009, 05:16 PM
If the CBR600RR forks are 48mm, what are the 1000/954 forks? Aren't they also shorter than the VTR?
Old 11-16-2009, 06:02 PM
They are 50 mm wide, and yes they are shorter than stock...
The thing is there are a number of higher bars that fit the 50 mm, less so on the 48... So that adds cost to do the rebuild... Also a lighter rider can use a 954/1000RR fork without changing internals... on a 929 it's marginal, a 600RR you really need to do some work...
Tweety is offline
Old 11-17-2009, 04:20 AM
Who are you?
Just_Nick's Avatar
Could someone measure the top and bottom holes of their 1000/954 triples?
salmanilla2000
03-29-2011 09:25 AM
firedog55
01-13-2011 06:43 PM
98VTRrider
09-14-2010 06:28 AM
grnell
02-25-2010 03:30 PM
dirty_\/
02-03-2008 05:42 PM
Quick Reply: cbr 600RR fork swap possible?
