BMC or K&N??
Re: BMC or K&N??
Stock Honda. Check out the results at the bottom of the page:
http://www.dynamohumm.com/HONDA/VTR%201000/my_vtr.htm
Here is a previous discussion:
https://www.superhawkforum.com/viewtopic.php?t=977
Good luck
Good luck
Guest
Posts: n/a
Re: BMC or K&N??
It's strange that people have had no power gains with the K&N, I just dyno'd mine with a new stock Honda filter, and then agian with the K&N. It gained 10HP and 3Lb Ft torque at the wheel! The mechanic running the dyno couldn't believe it.
Guest
Posts: n/a
My guess is you've rejetted and are running about 180 and 185 jets (maybe bigger). Too rich for the stock filter.
Did I guess correctly?
I have different cams, more compression and a full exhaust system. It runs perfect with 170 and 175 jets (Dynojet) and stock air filter at sea level. Needles on the fourth notch. #45 pilot jets.
Speed_Demon
Dec 26, 2006 11:16 AM
