best mods for performance?
Old Nov 23, 2013 | 02:12 PM
jlrutledge737's Avatar
jlrutledge737 is on a distinguished road
I've seen a lot of different threads about a certain performance mod but I'm looking for the best combination of mods I can do to my bike to make it run stronger after and of course torqueier so far I have is a stick coil conversion dino jet needle and springs micron single exhaust
Old Nov 23, 2013 | 02:19 PM
lloydievtr's Avatar
road racer v2 power
Riding school . Best bang for your buck
Old Nov 23, 2013 | 02:28 PM
As far as motor, lightening the flywheel IMO is the best bang for the buck. And really dialing the carbs (not just throwing a kit in there, but actually tuning them).
Everything else gets much more costly for the performance, and is best done in conjunction with each other (overbore, aftermarket cams, full exhaust, etc).
Old Nov 23, 2013 | 02:42 PM
After the flywheel, Dr Honda stacks and BMC street filter, then jet properly.......
Old Nov 23, 2013 | 03:17 PM
Imo???
Old Nov 23, 2013 | 03:29 PM
Flywheely IMO = Flywheel Isolated Modulation Oracle
Very tricky to lighten, but well worth the space-time jumps if you master it
Old Nov 23, 2013 | 03:30 PM
JK, IMO=
In My Opinion (Sometimes IMHO, In My Honest Opinion)
(which is somewhat redundant because I'm typing it, it is by nature my opinion)
and JK - Just Kidding
Old Nov 23, 2013 | 03:35 PM
I get it I was thinking about something else how about port and polishing the head?
Old Nov 23, 2013 | 04:59 PM
jerryh's Avatar
A good rider on a stock machine will torch the average guy riding a tuned bike.
Old Nov 23, 2013 | 05:17 PM
I'm looking to torch my buddy's gsxr 750 I'm a decent rider been riding for about ten plus years now he has full yoshi exhaust bazzaz fuel management and a k&n along with the front tooth gears down
Old Nov 23, 2013 | 05:30 PM
assuming you are equal riders, I hate to break it to you, but you don't stand a chance......
Old Nov 23, 2013 | 08:13 PM
Going the back end route? That would be much more expensive and no real results you will feel even if it's done right.
I say Flywheel as well!!! Best bet for the buck
Old Nov 23, 2013 | 11:12 PM
Lightened Flywheel changes the character of your engine for the better.
Makes it crisper in a sense!
The next best mod I have done is the rear shock shim, this sharpens the handling.
From there it gets costly, I know as my wallet is much lighter now.
Old Nov 23, 2013 | 11:49 PM
lloydievtr's Avatar
road racer v2 power
Gsxr750 vs vtr1000f !!
Gixxer wins unless it's rider rides like a Harley guy
Old Nov 24, 2013 | 12:00 AM
+1 Right on mate, I forgot to mention the 6mm shim
Cheers
Old Nov 24, 2013 | 06:20 AM
Cheers
I was thinking strictly motor mods... There are several things I'd do before the flywheel, but for more pep out of the motor, it would be my first.
I second the port and polish. If you look at port jobs on these bikes they really don't remove a lot of material b/c it's already formed fairly well in there . It'll help, but for the cost of removing the heads, the difference will be very small if it's noticeable at all. I'd do it if I were building the whole motor up, but not as an upgrade to a stock bike.
Old Nov 24, 2013 | 07:43 AM
Thinking strictly speed mods, yellow paint.
Old Nov 24, 2013 | 09:00 AM
Well if that's the case, I ditched all of the heavy fairings and added yellow LED's
Old Nov 24, 2013 | 09:09 AM
RobertLever's Avatar
No, everybody knows red paint is faster!
Old Nov 24, 2013 | 10:54 AM
I'm looking to build the motor I just want to know the best upgrades compaired to the expensive less gaining upgrades and pulling the motor is no big deal I can pull it and strip it down with out a problem
Old Nov 24, 2013 | 01:02 PM
If that's the case, than you can probably do several things, Flywheel, lighter pistons if you can get them cheap enough, maybe even with higher compression,
While you at it, you probably know how to port the valves, you can get an ignition advancer and so on....
Old Nov 24, 2013 | 04:05 PM
Wicky's Avatar
or just splash the cash buy an rc-51 to keep up with a gsxr...
Old Nov 24, 2013 | 05:15 PM
To get more out of your bike I don't believe that outright power is the way to go.
What about suspension and brakes?
Old Nov 24, 2013 | 06:02 PM
you'd need to spend money on it too......750 Gixxer is no slug..... modern engineering, light weight.... makes for a good package
Old Nov 24, 2013 | 08:21 PM
Agreed I am about to put a 900rd front end on it and I'm looking for a sleeper something people won't look at twice unroll they r passed and I dislike the rd51s good power plant looks goofy from wide front slim back
Old Nov 24, 2013 | 10:50 PM
I looked at an SP1 the other day and wasn't impressed with it visualy either.
The Storm, or as you guys call it the Superhawk has a timeless look by comparison.
Sleeper is the way to go.
I have many mods, however my bike still looks like a standard storm except for some blingy bits, and as our bikes are no longer available most people don't even know what they are.
Good luck with your endeavors, and if like me you get enjoyment out of making things better then you are about to have some fun, and maybe even give a few mates the ***** because they don't like to admit that bikes don't have to be the latest and greatest to cut it in the real world.
Old Nov 25, 2013 | 12:41 AM
Depends a little on the VTR, I'd say... I know a few GSX-R 750's that has to work too keep up in the twisties... The pesky 1000's keep sneaking away though, every time the road straightens at all...
But it's not really the cheap option at all... A port and a polish of the heads is just one item on a very, very long list of thousand dollar items...
Old Nov 25, 2013 | 03:49 AM
Mr. Rutledge, this guy here ^ is king of the sleepers. Fairly stock look, but pretty much everything is modified tip to tail to keep up with the faster bikes...
Old Nov 25, 2013 | 08:50 AM
Well guys what would you recommend I have a guy that owes me machine work mainly bc I paid to have a set of heads done and stuff happens and they never got done so I'm not worried about the cost on that end I would just need a list of parts that work well together and some performance tricks I plan on making the header going away from stock I believe the race header is 2.25 inches so I plan to make it. Not hard to do being I'm a welder and fabricator but not a motor builder
Old Nov 25, 2013 | 09:14 AM
Well that's a different story then... most people who ask the question like you originally asked it want a cheap bolt on part... and out of territory that I wouldn't want to pretend to have expertise in
