Am I running Lean?
Old Jun 19, 2013 | 03:32 PM
Livefreeordie89's Avatar
Livefreeordie89 is on a distinguished road
Am I running Lean?
I ask this because I noticed a small amount of back firing when I did my pair removal yesterday and bluing of the exhaust.
Mods
K&N
D&D slip ons
Pair block off
Carb
45 pilot
Dynojet kit
extra lift hole
5 clip needle with stock spacer
190 fmj 195 rmj
2.5 turns out
Any thoughts? bike runs decent, throttle response is poor when its cold but I figured it was a big V twin thing but maybe someone has some insight? Runs strong when warm, sometimes throttle response downshifting is a little laggy sometimes its perfect.
Old Jun 23, 2013 | 07:09 AM
If you do some searching you'll find that your current carb set up is not what most (all) members here, that are very experienced at such things, will recommend against such a set up.
That said, you can pull the enrichment (choke) **** out a bit and see if the popping gets better or worse. That will tell with out a doubt if your lean or rich.
J Bragg
Feb 4, 2011 06:32 PM
allaking
Nov 10, 2008 11:47 AM
Speed_Demon
May 4, 2007 08:18 PM
apbrian112
Aug 11, 2006 02:14 AM
cb21983
Jul 24, 2005 10:26 PM
