954 calipers only, will it works ?
Old Sep 5, 2006 | 05:25 AM
roadrun_fr's Avatar
roadrun_fr
Hi,
Lots of posts about upgrading brakes.... but,
I'm looking for a better initial bite of braking power and more brake power without too much effort on the lever : one finger braking power...
I've SS lines, EBC HH pads, stock calipers, stock MC.
Upgrading to 954 calipers would help ?
Would I absolutely need a larger MC ?
Old Sep 5, 2006 | 09:07 AM
954 calipers will not bolt on to Superhawk forks. The master cylinder is a better upgrade along with good pads and lines.
Old Sep 5, 2006 | 01:40 PM
Lefin102's Avatar
You can upgrade the system with any 929,954 or rc51 calipers and master cylinder. You will have to mill out some material from the calipers to make them fit the Super Hawk forks. At the very least change the master cylinder.
Old Sep 5, 2006 | 02:36 PM
roadrun_fr's Avatar
roadrun_fr
So, looks like I should first upgrade to another MC.
Which is the best MC size to use with stock calipers ?
16mm, 17mm, 19mm ?
MC CBR929, CBR954 ?
thanks ;-)
Old Sep 5, 2006 | 02:51 PM
jschmidt's Avatar
jschmidt
Get the one that matches the calipers you choose. For instance, early rc's used a 19mm m/c and later ones used an 17.5.
I have complete front rc brakes. Its a great mod.
Old Sep 5, 2006 | 04:14 PM
I have mounted a RC master cylinder on mine (not sure about the year but think it is a 2003). That, along with braided steel lines and EBC HH pads makes for a wonderful front brake system. I would imagine that RC calipers would likely be another step up but I am quite happy with the set-up I have now, it does everything I need it to do.
cheers
Mikstr
Old Sep 5, 2006 | 07:54 PM
SlowHAWK's Avatar
I have a RC-51 setup on my Hawk.... I like it, definitley bite harder with less lever effort. Here's a link with a bunch on the pics I posted.... I've heard the 929/954/F4i calipers will need the same work done to them...
https://www.superhawkforum.com/forum...ystem+Overhaul
If the link doesn't work, do a search for Brake System Overhaul.... you'll find it.
J.
Old Sep 5, 2006 | 10:40 PM
What I don't understand is how the RC/929/954 calipers are all that much different than the stock VTR calipers. They don't look much different and they are still 4 piston. Are the pistons different sizes? I think the M/C alone made a huge amount of difference, at least as much as the pad change. Lines will give you "feel". The M/C gives you less travel, increased lever firmness, but less feel (made up for by lines). The pad change gives the increased braking power.
Old Sep 6, 2006 | 04:12 AM
Here is part of the answer
Originally Posted by roadrun_fr";p=&quot
Do the superhawk stock pads fit with the RC51/929/954/F4i calipers ?
No.... the RC/929/954 pads are larger and have 2 pins at each end holding them in place within the caliper.... if you look at the comparison photo, you'll see the Hawk pads are held in by 1 pin located in the center, and are smaller as well.
Taken from another thread.
Add in some differences in piston size, designed in stiffness of the newer caliper. or just the internal differences.
Old Sep 6, 2006 | 05:24 AM
Lefin102's Avatar
Brake Teck and GP Teck both offer master cylinders along with calipers and pads. But it's cheaper to get one off ebay.
good luck
Old Sep 6, 2006 | 06:30 AM
SlowHAWK's Avatar
The RC calipers while looking simliar in size, have larger pistons internally.... and as stated the pads are also larger (have more surface area) as well.
Old Sep 9, 2006 | 08:30 AM
jschmidt's Avatar
jschmidt
Next to each other, they don't really look similar in size or construction. They are clearly superior. It's not even subtle.
Old Sep 9, 2006 | 08:36 AM
killer5280's Avatar
And they're smaller and lighter. It's a win/win all around.
Bngt
Oct 30, 2012 01:50 PM
mikstr
Jan 7, 2011 03:06 AM
MisterMohawk
Apr 8, 2007 04:53 PM
roadrun_fr
Oct 3, 2006 08:35 PM
