900rr front end installed
Old Aug 9, 2006 | 04:54 PM
selztoad's Avatar
installed my 900rr front end today and also got my rear seat cowl front end feels much better now but i still need to find a comfortable setting for my clip ons and the angle of the forks
Old Aug 9, 2006 | 06:29 PM
superbling's Avatar
Nope, sorry it never happened without pictures!
Old Aug 9, 2006 | 07:37 PM
Scooberhawk's Avatar
Seņor Miembro, Ay Caramba
I'm sure he speaks for all of us. In other words, we're curious.
Old Aug 10, 2006 | 09:38 AM
superhawk22's Avatar
Did you measure it? seriously though was it like he said,(lengthened for a vtr), or did you just put it on anyway?
Old Aug 10, 2006 | 12:26 PM
selztoad's Avatar
Yeah I measured them and the 900rr forks ended up being about a half inch longer. I still have some tweeking to do with how much to have above the top triple, if anyone has the measurement for stock from middle of axle to the top of the top triple i would appreciate it. i will try and get some pics....i only paid 150 for the whole thing and he just had the oil and seals changed
Old Aug 10, 2006 | 12:44 PM
Hmm...I wonder if they were compensating for the different offset of the 900rr triples? I know I've posted the measurments on here before, I'll see if I can find them.
Old Aug 10, 2006 | 02:11 PM
selztoad's Avatar
I found your post 30.5 inches...thanks!
Old Aug 10, 2006 | 04:22 PM
Glad I could help.
Old Aug 11, 2006 | 03:11 AM
mr.billet's Avatar
mr.billet is on a distinguished road
What year 900rr front end did you use? There are differences between the 93-97 front end and the 98-99 front end with the 98-99 being the better set to use.
Old Aug 11, 2006 | 05:10 AM
selztoad's Avatar
Yeah I know the later is the better , but i think it was from a 95, there is only rebound and preload. My stock front end need new springs and seals and that would have run me about $150 which is what i paid for the 900rr front end. so i went with the beefier 45mm 900rr front end
Old Aug 11, 2006 | 04:34 PM
selztoad's Avatar
ok ok here are the pics
Old Aug 11, 2006 | 04:42 PM
So I guess you need to buy a fender eh?
Old Aug 11, 2006 | 04:44 PM
selztoad's Avatar
yeah, I may eventually get a carbon fiber one because the one that came with the front end was a horrible pale red color, but i have to save up for a rear shock
Old Aug 11, 2006 | 05:57 PM
EngineNoO9's Avatar
so these 900rr forks HAD been extended or what? I think I'm gonna still go gixxer1000 or 929/954 front end for the inverted blang blang factor as well as being mega beefy
Old Aug 11, 2006 | 06:17 PM
selztoad's Avatar
yes there were extended, and like i said $150 for forks, top and lower triple wasnt bad, considering my stock ones needed a rebuild (fluid, springs, seals)
Old Aug 12, 2006 | 02:11 PM
superbling's Avatar
Looks great Toadster.
Until you get a fender, you might check the electrical isle and see if they have red zip ties. I've never looked for them put I seem to recall seeing different color ones the last time I bought some black ones.
So if your running a VTR 17inch wheel AND the forks have been extened, might the front end be too tall now?
Old Aug 12, 2006 | 02:25 PM
selztoad's Avatar
Well I have a little more fork coming thru the top triple than stock to compensate..I think I may have the front end a little too low with the stock rear shock because I rode it pretty hard yesterday and was running into ground clearance issues a little more than usual....I am trying to figure out what rear shock to get..biggest thing is having adjustable ride height
Old Aug 12, 2006 | 02:31 PM
superbling's Avatar
Yup once you update the front, it's becomes even more evident that the rear needs help. Good luck in your search.
Old Aug 12, 2006 | 02:51 PM
selztoad's Avatar
yeah, I am thinking about the WP shock, on LE site for $630...it has adj compression , rebound, and ride height....extra for a remote res...but i dont need that..
thedeatons
Aug 2, 2013 04:40 PM
MC Leather
Feb 5, 2010 02:25 PM
Letsrideinsc
Mar 1, 2007 08:12 PM
Letsrideinsc
Nov 8, 2006 08:29 PM
selztoad
Oct 1, 2006 10:15 AM
