2 into 1 exhaust mod
Old Jul 28, 2012 | 06:44 PM
karmgearhead's Avatar
karmgearhead is on a distinguished road
I wanted a 2 into 1 and looked at some of the other superhawk exhaust photos and decided I wanted a high mount.I purchased a micron high mount for a 00 r1 off ebay. I cut my exhaust at the collector and installed a 1999 vfr 800 exhaust gasket,it fit perfectly. The mid pipe did not have the exact bend I wanted so I found on ebay a polished 2-1/4" stainless 45 degree elbow. and trimmed the midpipe and elbow to length.took both pipes to a muffler shop that had a hydraulic pipe expander and had the midpipe expanded to accept the elbow.Took them back home made a few alignment marks and had them tig welded.I also trimmed 6" off the can.It runs great and sounds great also.
Attached Thumbnails 2 into 1 exhaust mod-2012-07-28_19.12.59.jpg   2 into 1 exhaust mod-2012-07-28_19.14.16.jpg
Old Jul 31, 2012 | 09:31 PM
nath981's Avatar
nice job and it's a win-win: got rid of 20+ lbs and it looks, sounds and runs good too. Thanks for sharing.
Old Jul 31, 2012 | 10:39 PM
oahu hawk's Avatar
geezer
Nice!...personally, I would have shortened the can a skosh less...
Old Aug 1, 2012 | 05:37 AM
I did practically the same thing a few years back (though with a Blue Flame slip-on and link pipe for a 98-99 R1; believe pics are still up in gallery section). The bike ran decently though I noticed a dip in teh mid-range, something confirmed by teh dyn (between 4,800-6,500 rpm). Peak power was virtually unchanged although peak torque was down slightly.
Old Aug 19, 2012 | 08:10 PM
99superhawk_Dom's Avatar
99superhawk_Dom is on a distinguished road
If you used a 2 1/2 or 3 inch pipe from the merger on would that give you close to the same back pressure? You can see clean through the cans i have on now. Doesn't that change the back pressure?
Old Aug 20, 2012 | 08:45 AM
aja's Avatar
aja
3"??? I dont even run 3 inch on my car, and having that big of a pipe on the end won't help at all.
Old Aug 20, 2012 | 03:09 PM
gotta_gofast's Avatar
gotta_gofast is on a distinguished road
Why stop there? Go to a diesel shop and pick up some 4".
Old Aug 20, 2012 | 06:30 PM
Demon's Avatar
1 down 5 up
Demon is on a distinguished road
Clean setup...
Old Aug 20, 2012 | 08:49 PM
Looks good, what did you do to jet it. My 2 into one was finicky. Still not quite right.
Old Sep 1, 2012 | 02:09 PM
scottiemann's Avatar
looks like you could use a new rear tire as well...
the can looks good too very clean and i like the blue
Old Sep 2, 2012 | 01:09 AM
lloydievtr's Avatar
road racer v2 power
well done i did mine earlier this year
Old Sep 2, 2012 | 01:13 PM
JamieDaugherty's Avatar
I've seen both good and bad results with a 2-1 setup, glad to hear yours turned out well. Maybe one of these days I'll give it a shot on my bike!
Old Oct 17, 2012 | 11:19 AM
streetfighterhawk2000's Avatar
streetfighterhawk2000 is on a distinguished road
What did y'all Jett the bike to after installing the new 2 into 1 pipes I've been fighting with my jetting for a month now I have a factory pro and dyno jet kit with a kn filter help please!!!
Old Oct 17, 2012 | 11:44 AM
3 wrong things combined does not make one right... K&N filter = wrong, combining Factory Pro and Dynojet jet kits = wrong... Add a 2-1 header, and you get a friggin headache...
Old Oct 17, 2012 | 12:09 PM
so what filter n jet kit should i use with the 2 into 1 exhaust set up?
Old Oct 17, 2012 | 12:11 PM
right now the factory pro kits in the bike just got a dyno jet one thinking that that one may sovle the problem but then it was running to lean
Old Oct 17, 2012 | 12:15 PM
Wicky's Avatar
You'll best take it to a dyno to get it setup as you've got so may variables err.. varied.
Old Oct 17, 2012 | 12:23 PM
man i really didnt want to do that lol the guy who had it before me set the bike up when i had pulled it down the carbs had a 178 factory pro main and 180 rear but what was odd is he had the the slides with 3 lift holes insted of two and the slide springs where cut in half on each side i guess where im stuck is how to set the fuel neddle. he was also running 50kehien jets and said to turn the mix screws to 1-1/2 to 2 out and i know that you have to set the tps sensor as well have that set at 495 give or take
Old Oct 17, 2012 | 02:16 PM
So what's the timeline here so that we can get this straight?
1) It was running great, had a Factory Pro kit in it.
2) You put a 2-1 exhaust on it and it didn't run so well.
3) You decided to adjust the carbs and bought a DynoJet kit.
First off, I think the shorter spring is a stiffer one that came with the Factory Pro, not just a cut stock one. The jet kit also has instructions to drill out a third hole, so that wasn't just the PO's idea.
Did it always have the K&N or did the stealership put that in?
Personally, if it were me, I'd go back to stock everything and make steps from there (or maybe 8542Hawk's setup). Some people have got the K&N to work, some have got the jet kits to work, but stock will definitely work with a stock bike. Then, start adjusting for your exhaust. It won't run well at first with this setup, but at least you're not playing with several variables at once. If you can grab a stock set of carbs and stock filter at a reasonable price that is...
Actually, personally, I'd cut my losses and go to a stock exhaust header/mid pipe as the 2-1 just doesn't seem worth the effort IMO (and put my energy into something that will get the bike running better rather than just back to stock)... but I get that if you've got a specific streetfighter look in mind this isn't an acceptable answer, haha! I think Autoteach had a custom exhaust that he spent a lot of effort tuning for and may have some pointers...
I mean this as a friendly request, but it's much easier to diagnose if we get the details in a little more order... smartphone no punctuation text reads kind of frantically. No offense meant by that, just tryin to help
Old Oct 17, 2012 | 02:31 PM
Old Oct 17, 2012 | 02:32 PM
When I got the bike it had a 2 into 1 it's never had a stock exhaust on it since I've had it
Old Oct 17, 2012 | 03:09 PM
Ah ok, so it was running pretty well when you got it? What did you do/when did it start running bad?
Old Oct 17, 2012 | 03:28 PM
Ya ran great I let some guy at the Honda house sync the carbs and that was not the problem it was the cracked main housing he neve found that but he moved my fuel needle mix screws so now I have no clue where they where set at.
Old Jun 2, 2013 | 07:11 AM
update. replaced micron with yoshi
I changed my slip on from the micron to a yoshimura trs that I trimmed 4-1/2" off.It sounds great,I think it looks better too.
Old Jul 18, 2013 | 06:58 PM
bpw's Avatar
bpw
bpw is on a distinguished road
Hey karm, which ever way floats your boat they both look fantastic great job! I lean slightly to the blue can but its just preference. thanks for posting I may reference this one day.
ride57
Apr 17, 2016 10:09 PM
Sep 25, 2011 12:06 PM
mikstr
Aug 8, 2010 05:48 AM
ImitationCrab
Nov 20, 2009 03:26 AM
thehandyman
Nov 29, 2006 12:38 PM
