Urethane over duplicolor primer?
Old Jun 25, 2011 | 09:32 PM
spladle160's Avatar
I'm prepping to repaint my bike. After repairing body work doing surface filler and removing decals I used Duplicolor Scratch filler primer (FP101) to go over spots I had worked on. I was planing on doing a solid coat of it then spraying this urethane base candy and clear. EyeKandy Kandy Paint Motorcycle Kit Now I'm worried that the primer may be a lacquer and I shouldn't use urethane over it. I can't find any real info on the primer. Any help would be great.
Old Jun 25, 2011 | 09:46 PM
poppazuti's Avatar
Head Scratcher
I've used the same primer with both lacquer and enamel paints with no problems. My suggestion would be to test paint a smaller piece (seat cowl or that little piece of fairing that goes under the headlight) so you don't lose a ton of time re-prepping the piece if the test goes awry.
Old Jun 26, 2011 | 07:30 AM
spladle160's Avatar
Awesome, nothing like test data for peace of mind. Thanks Pops I'll be sure to post pics when it all gets done.
dzldub
Nov 11, 2012 02:04 PM
uchi
Dec 10, 2010 05:26 AM
Otto Man
Feb 2, 2007 12:57 PM
mamisano
Jul 8, 2004 08:32 PM
uberhawk
Jun 30, 2004 10:59 AM
