Swingarm Spools
Old Mar 14, 2008 | 08:39 PM
Arctic Fire's Avatar
Arctic Fire is on a distinguished road
Swingarm Spools
Anybody know if these will fit anywhere? Drill and tap or what?
Swingarm Spools
Lemme Kow
Old Mar 15, 2008 | 06:10 AM
It’s been covered here a few times .. There are three choices.
Weld in some threaded bosses
Drill and install threaded inserts
Forget the spools and use a lift that goes under the swing arm.
I bought a swing arm to do the welding option, then decided , just to use an underarm stand..
There are proponents here of both the first too methods, they have their reason not to do the other way..
As far as we have heard, neither method has caused a swing arm to fail.. so I’d say no real evidence is out there one way or the other. The OEM drills holes in the swing arm.. The OEM welds on the swing arm,,,, Me, Once I find a donor swing arm,, I’m doing a brace and spools.....welded all the way.
Old Mar 15, 2008 | 06:18 PM
autoteach's Avatar
you could do a top hat setup that is threaded on the inside, goes thru both sides of the swingarm and gets welded on both sides. This would prove to be very strong. all you have to do is make the part or have it made. For me this isn't a big deal, but for most this would suck.
Old Mar 16, 2008 | 02:45 AM
My TIG skills are not up to par, I am goignt o find a "seingarm brace" type stand, I will search to see if anyone has any suggestions, thanks!! (CT)
jdahkvtr1000
Dec 14, 2009 03:16 PM
fishpimp1
Jan 9, 2009 08:26 AM
floppyhat
May 23, 2008 02:33 PM
Yardstick
Jun 18, 2006 11:46 AM
ReTodd
Mar 24, 2005 01:18 PM
