Mounting a Radar Detector, GPS, or Camera
Old Mar 30, 2006 | 09:36 AM
Randman's Avatar
Moderate-whore
Anyone have one of these devices mounted on there hawk?? Radar, Camera, GPS etc..... what type of mount? Where is it mounted?
Any info would be nice....I am not looking to spend an arm and a leg either.....lol
Old Mar 30, 2006 | 10:16 AM
Re: Mounting a Radar Detector, GPS, or Camera
your lucky day:
http://cgi.ebay.ca/ws/eBayISAPI.dll?...MEWA%3AIT&rd=1
cheers
Mikstr
Old Mar 30, 2006 | 10:20 AM
one more:
http://cgi.ebay.ca/Tank-Camera-GPS-R...QQcmdZViewItem
Old Mar 30, 2006 | 12:18 PM
Yardstick's Avatar
Yardstick
I'm not sure where it came from, but the carbochicken has a little nub on top of the steering stem that I can attach a camera mount to. The camera mount is like something you'd find on top of some tri-pods. It was modified (by the P.O.) with a small flat piece of wood with velcro on top. He used a radar detector on it, but could be easily modified to accept a camera or GPS. I can snap a pic if you want.
Old Mar 30, 2006 | 03:07 PM
Randman's Avatar
Moderate-whore
Originally Posted by mikstr";p=&quot
Saw this one on Ebay before posting, I have a tank bag so that is out....Thanks anyway...
Old Mar 30, 2006 | 03:09 PM
Randman's Avatar
Moderate-whore
Pics would be great, I might be able to duplicated it if I see it....Thanks .....sippin coffee eagarly awaiting response....lol....
Old Mar 30, 2006 | 06:33 PM
Yardstick's Avatar
Yardstick
Here you go!
Old Mar 30, 2006 | 06:45 PM
Randman's Avatar
Moderate-whore
That little round piece that sticks up that it attaches to....I don't have that on my bike....it is a flat piece....yes I know I am very technical with my description...lol....Not..
Thanks for the pics....I think I can figure some thing out and make it work....
Old Mar 30, 2006 | 08:03 PM
Yardstick's Avatar
Yardstick
I think it would be pretty easy to create that mounting rod that sticks up with the right tools (mainly a lathe). The tripod top would be an item to buy.
Find a piece of rod stock about the right diameter for the tripod top.
Cut a band in the rod to make clearance for the clamp bolt on the mount.
Turn the other end of the rod down to the ID of the steering head bolt. Make the length long enough to go in maybe 2" or so.
Drill a thru hole in the tap size of whatever bolt you want to use, (M6 or M8 maybe).
Cut the small end of the rod at a 30-ish degree angle.
Tap the smaller piece that gets cut off and drill the top portion to a thru hole (and countersink for the head of the bolt)
Once it was screwed together loosely you could put it down the middle of the steering head bolt and tighten it up. The angle will bind the lower part and keep it held in the head bolt.
If there was a specific tripod mount that worked best, maybe someone could make a small production run of the steering head mounts.
Old Mar 31, 2006 | 08:52 AM
Randman's Avatar
Moderate-whore
Thanks, I'll poke around and see what I can come up with....I like the tripod top, in fact I have one of those.....
BluStreak
Feb 1, 2009 08:51 PM
CentralCoaster
Nov 18, 2008 11:38 PM
joe6pack
Dec 3, 2007 04:48 AM
TheDarkKnight
Aug 3, 2007 06:30 AM
Alic
Feb 21, 2005 09:16 AM
