Intergrated LED tail light installation
Old May 21, 2012 | 09:16 AM
spitfirerecords21's Avatar
www.SpitFireRecords.net
spitfirerecords21 is on a distinguished road
I hope Im not reposting a thread thats already been discussed. I didnt see any that gave specifit instructions on how to install the LED tail light with intergrated turn signals.
I bought it from Ebay. It came with nothing at all but the tail light. I know from reading other threads that the 2 yellow wires are for the turn signals, but how do i wire the 2 seperate stock signals wires (each having 2 wires) into the 2 yellow ones?
Also theres the Black, Red, and Green wires. The stock is two seperate bulbs, One thats constant running, and one thats the high brake light. How do I wire those 2 bulbs into the LED light's black, red, and green wires?
Any help would be greatly appreciated. I have a 1998 SH.
Old May 22, 2012 | 07:32 AM
aja's Avatar
aja
Use connectors to hook up the blue and Orange to the stock wires, test them first to make sure you have the right wire in the right spot.
The others are connected to the wires with the tail light plug. Mine came with a female end and just plugged in, you may news to cut off one plug and connect the wires. The other plug stays unplugged.
Old May 22, 2012 | 08:13 AM
led tail lights
I dont have a orange wire at all. From the tail light like I said theres a red, black, and green set of wires coming out of one section together with no connectors on them at all or in the box. and a seperate set of two solid yellow wires.
The bike on the other hand has two bulbs (one thats constant running and one that only lights up when u squeeze the brake). Each bulb has 3 wires running into the connector behind the bulb (a red, and black, and a purple).
Im not quite understanding your reply?
Old May 22, 2012 | 09:01 AM
If your bike is stock, it should have two bulbs that's always on, with a second filament for the brake light... Each bulb has three wires, one green which is ground, and one brown that's 12V and one green with yellow dots... The last one is the brakelight...
If not, then someone have been messing with it already... and by your description it certainly seems like it...
Get a multimeter... Connect it to the wires (bike!), and find out which wire is which... Put the negative measuring lead to the frame, and you get 12V on on wire, 0V on two... Pull the brake lever, and one of the last two will show 12V... The last one still showing 12V is ground, the other the brake light...
Then hook up the new light, I'd try the green as ground first, and red as 12V... But either way, if you haven't got the ground right, it won't light at all, and if you got the others mixed up, you will see one is brighter...
The two yellow ones are the signals... One of each goes to the orange and blue respectively for each signal... The signal also has one green wire for ground, but that's not used, as the whole array grounds from one cable...
Old May 22, 2012 | 09:02 AM
BTW, this is how you wiring should look like, and did when the bike left the factory...
Attached Thumbnails Intergrated LED tail light installation-vtr1000f_-_superhawk.jpg
Old May 22, 2012 | 09:18 AM
HRCA#1's Avatar
Thumbs up
Tweety,
That's one of the most useful attachments I've ever seen for SH electrical, certainly better than the factory manual!
Old May 22, 2012 | 09:35 AM
Originally Posted by HRCA#1
Tweety,
Then, you get a bonus...
www.tweety.se/links.php There you can dowload it in a higher resolution...
Old May 22, 2012 | 09:59 AM
HRCA#1's Avatar
Thanks Tweety..cool site!
JakeT
Oct 12, 2013 07:58 PM
Anto
Sep 12, 2009 11:47 AM
Anto
May 5, 2009 05:20 PM
CNI Dawg
Jun 8, 2006 07:28 PM
