Help with clear tail
Old Feb 21, 2012 | 01:29 PM
Camelninja's Avatar
Camelninja is on a distinguished road
Got a tail light before I left to play soldier, now Im back and I cant figure out how to install the light, and Im afraid of ruining it. The tail light is a clear LED with integrated turn signals, it has 3 wires coming out of the left hole (red yellow and black) and two coming out of the right hole, (yellow and blue) if you need pics lemme know and Ill try to get some posted. Thanks for the help in advance!
Old Feb 21, 2012 | 01:49 PM
aja's Avatar
aja
The yellow and blue are the signals, the others are for the brake light. Mine had a female end for the stock wiring plug already, so you will need to get one or cut the stock off and connect the wires to the harness.
Old Feb 21, 2012 | 01:55 PM
Camelninja's Avatar
The colors arent the same and I am not exactly good with electronics, can you tell me which colors link up with what? also the stock brake light has two bulbs, should I only use the wires from one bulb and tape up the others?
Old Feb 21, 2012 | 02:09 PM
You know what brand of clear light you have by any chance?
Old Feb 21, 2012 | 02:43 PM
Camelninja's Avatar
I think its clear alternatives.... but the GF threw away the box while I was off soldiering
Old Feb 21, 2012 | 06:24 PM
stumplove's Avatar
stumplove is on a distinguished road
You can hook the black wire up to the negative on a 9V battery and then test out what wires run what lights and label them accordingly.
Old Feb 26, 2012 | 09:01 AM
aja's Avatar
aja
I'm going off memory, but for the 3 wires in the one plug, red is brake light, yellow is running light, black is ground. Hook those up to their respective wires in the harness.
The other yellow and blue go to the turn signals, which you color match to the wires that plugged into the oem turns.
If you need I can snap a picture of mine, just let me know.
Old Feb 29, 2012 | 04:20 PM
Camelninja's Avatar
Finally got the tail light working... works great and looks even better. Only blew one fuse in the process :-P Thanks for all the help guys!
seaton001
Mar 19, 2007 05:46 AM
Radiaoktiv
Nov 17, 2006 12:54 PM
mikecronis
Apr 16, 2006 12:10 PM
mamisano
Apr 3, 2005 12:41 AM
mamisano
