Dutch streetfighter build
Hi guys,
After riding around on my black VTR for a few years now, I have started to work on my vtr streetfighter past summer. This is my normal streetbike; http://www.mijnalbum.nl/Foto-8CF7HBR7.jpg See here more images VTR Of The Month - August 2010 - WINNER: Revelation! - SuperHawk Forum It has been a long cherised wish; to build my own streetfighter. Anyway I came across a special VTR, an ex race bike with some nice extra's. It used to compete in "battle of the twins". http://www.mijnalbum.nl/Foto-WXUDO7D8.jpg http://www.mijnalbum.nl/Foto-PRNSZJRD.jpg Extra's oa; - Magnesium wheels - WP front front forks - WP rear shock - Brembo brakes + discs - Highmount exhausts - Steering damper - Weight reductions - and more... This is the way I bought it; http://www.mijnalbum.nl/Foto-FM4QGY8G.jpg http://www.mijnalbum.nl/Foto-6UEOFO67-1.jpg It was running poorly at that time, but I was going to take it apart anyway. The engine was said to have 130 hp; cams, ported etc. So the engine I have sent to Roger for an overhaul, but it wasnt as tuned up as the seller made me believe.. and the gearbox was completely fucked. So bitterly dissappointed I got yet another (stock) engine. That was the cheaper solution. A real pitty never the less. Now the main ingredients for the build: - Aprilia Tuono 2007 rear - 19L tank (customized) - Triumph speedtriple headlights - Rear radiator mod - Yoshimura tri oval exhausts - CBR rear brace mod - SP1 dash - Lightened flywheel - Carb kit, stacks - Carbon clutch plates - Manual CCTs There's loads an loads more mods of course... Dissasembly & start of build http://www.mijnalbum.nl/Foto-ZZJJF3BO.jpg http://www.mijnalbum.nl/Foto-EZLFOTD7.jpg http://www.mijnalbum.nl/Foto-4B8QXKY7.jpg http://www.mijnalbum.nl/Foto-NEBJ7RQQ.jpg http://www.mijnalbum.nl/Foto-3BQ66CZ3.jpg I will continue in next post... dont want to risk to make mistake and lose this bit! |
Since pictures say more than thousand words, I'll just keep posting pics.
This is somewhat chronological order http://www.mijnalbum.nl/Foto-YWGSE87Y.jpg http://www.mijnalbum.nl/Foto-ZI8OVBNP.jpg Tried the exhausts on the bike. http://www.mijnalbum.nl/Foto-ZXTX4VSJ.jpg Have put them away for now, to keep them in this mint condition. Link pipe will have to be made custom, going for this look http://www.mijnalbum.nl/Foto-IRKFUAPF.jpg Firstly I was leaning twrds a single sided swingarm, but then I would have to swap back to a stock rearwheel. I decided to keep the magnesium wheels as a set. So I had to do something with the original swingarm... Bought a 900rr swing (cheap of fleebay), cut off the brace and had it welded onto mine. http://www.mijnalbum.nl/Foto-UYXRUW3M.jpg http://www.mijnalbum.nl/Foto-W6M8I4GY.jpg Will be fitted with real carbon hugger http://www.mijnalbum.nl/Foto-KIZEDZBL.jpg Subframe welded http://www.mijnalbum.nl/Foto-GJCXIXXR.jpg http://www.mijnalbum.nl/Foto-TEDAQWTA.jpg Have bought a radiator from crashrat and it seems to fit. http://www.mijnalbum.nl/Foto-PYS4MWMT.jpg http://www.mijnalbum.nl/Foto-KX3LFE7G.jpg Even more stuff has to go under the seatcover... tight! http://www.mijnalbum.nl/Foto-YX8ECKAT.jpg But it all fits under the cover http://www.mijnalbum.nl/Foto-8KSHTIND.jpg Wiring, relocation and re wiring http://www.mijnalbum.nl/Foto-OFFOM3KF.jpg http://www.mijnalbum.nl/Foto-3SOWBPZ7.jpg http://www.mijnalbum.nl/Foto-XKQP6FRD.jpg http://www.mijnalbum.nl/Foto-XFEBEM33.jpg http://www.mijnalbum.nl/Foto-6ZSM7NAS.jpg Progress http://www.mijnalbum.nl/Foto-JE68XNJV.jpg http://www.mijnalbum.nl/Foto-LEGU6H7D.jpg Bought a SP1 dash http://www.mijnalbum.nl/Foto-BPAWXPGP.jpg http://www.mijnalbum.nl/Foto-BKTHM8MM.jpg http://www.mijnalbum.nl/Foto-DQIXM8P3.jpg http://www.mijnalbum.nl/Foto-F3ZUM74O.jpg Still havent gotten it to work completely. Does anyone have a 100% working one on his bike and is willing to share the right combo's? Seen a topic about it, but it doesnt clarify everything.... help please? Tank is modified a bit now; had those gaps filled and dent repaired. These 19L are getting hard to find in good condition... http://www.mijnalbum.nl/Foto-GZ7FITHM.jpg And this is where I am now. Got my pyramid belly pan in this week. http://www.mijnalbum.nl/Foto-CICKXBON.jpg http://www.mijnalbum.nl/Foto-WYTEVGJR.jpg Will have to finish building it now first, my "short" list: - Complete the wiring, - Relocate ignition key - make coolant pipes from right front to left rear. - Fix the dashboard - Fit headlights - Build up engine with the mods, - Fix the carbs etc etc. - Dyno dyno dyno When I have it running properly, will take it apart again for painting/coating. http://lizelot.net/wp-content/upload...andse-vlag.gif That is all for now, if you have any thoughts... let me know! |
Sooooo badass. The tuono tail is my favorite tail ever made. Amazing work so far!
i'm movin over there so you can build me one of those. haha Lookin goooood! Nice work Rev. You'll need to write a book to go along with all those mods.
Originally Posted by nath981
(Post 321578)
The other one also has more mods than I can remember. Where abouts in the Netherlands are you moving to? Is your bike coming along? Getting a Dutch plate shouldn't be a problem... can help you with that if needed. |
Originally Posted by t-dogg
(Post 321576)
I absolutely love the look of this one, with the slim cans: http://www.mijnalbum.nl/Foto-YPVP3MUI.jpg http://www.mijnalbum.nl/Foto-CG3NGQLZ.jpg But I bought these yoshimura cans, so is going to be a bit different http://www.mijnalbum.nl/Foto-DN7J36FI.jpg So far everything just seems to fall into place For example the subframe; the 2 lower legs fit "as is". Had to cut back the top 2, no problem there. Lined them up, up to the angle that the saddle touched the tank. Whataya know... it is lining up perfectly: http://www.mijnalbum.nl/Foto-CQHAU4PK.jpg |
VERY COOL!
Originally Posted by Revelation
(Post 321583)
Jep I am trying to keep track of it all, but will be hard to make a FULL list.
The other one also has more mods than I can remember. Where abouts in the Netherlands are you moving to? Is your bike coming along? Getting a Dutch plate shouldn't be a problem... can help you with that if needed. thanks for the kind offers and we will be watching your masterpiece evolving. |
Nice job and very creative, that's the spirit! Always think how to make it better an unique, especially for your self!
Where are you in NL? |
Originally Posted by NHSH
(Post 321626)
Where are you in NL? Actually did a tour with the other bike yesterday. Nice! :D It was abt 10 degrees, in december! |
My Mom lives on the other end, Groningen ;)
10C wow, that is warm for end of december
Where can one find that good looking pyramid bellypan?
(Post 321645)
Originally Posted by mertechperformance
(Post 321660)
I consider myself lucky getting one for the price I paid. They can still be ordered NEW from Pyramid plastics... see here.. But they dont come cheap! |
This evening made the coolant lines..
http://www.mijnalbum.nl/Foto-NWS4FO4Z.jpg My parents neighbour helped me out with it. He is a professional and makes it look so easy. http://www.mijnalbum.nl/Foto-QJNVYEWB.jpg Tubes are squeezed in just right and line up perfectly! http://www.mijnalbum.nl/Foto-LFQMNSVF.jpg http://www.mijnalbum.nl/Foto-RZV8TCVI.jpg http://www.mijnalbum.nl/Foto-43IFEBGZ.jpg Parrallel under subframe to connect to the rad http://www.mijnalbum.nl/Foto-TF4TYNAA.jpg Return tube will be a inside the subframe http://www.mijnalbum.nl/Foto-OTAQBYCL.jpg This steel version is the mockup, he will make them again in copper. Will have the final version powdercoated black, same as subframe. Trust it will be hardly noticeable when finished. |
Any updates???
(Post 323986)
Any updates???
Busy with work, going out too much and other stuff... Maybe I will get some stuff done on saturday again. I have been struggling to get past the wiring. Its just no fun! Aspecially the additional wiring for the fans was an obstacle. Need to wire 3 relais to switch on/off and from serial to parallel.... Sent it to someone who will fix it for me now. Progress: Radiator has been modified, so that that tip that points down is now lining up with the tube. I did buy some new sparkplugs, filter and oil last week. So slowly I am getting to putting her back together again. Hopefully will do testrun end of this month... Dash still not fully functional... cant get this damned tacho to work! :mad: Need to get my link pipe sorted also, my welder is always too busy. |
I am running an RC51 cluster also and my tach doesn`t work either. I am hoping that switching teh R/R to a MOSFET unit will cure that. We`ll see....
Originally Posted by mikstr
(Post 323999)
Ooowww finally a companion in my suffering! I am about to go to a guy with my dashboard to hook it up to a runnin' SP1. Just to check whether the damned thing isnt faulty! |
(Post 323999)
I think Tweety had his working, but it was from a cbr1000rr I believe. Maybe something to look into...
(Post 324046)
Cant seem to figure out why everything works, besides the tacho. :eek: Think 7moore7 has an earlier CBR(600) dash fully functional? |
Just ordered a box full of radiator hoses of fleebay..
Need some sharp bends of 25mm to make that turn from the waterpump. |
Received a box full of radiator hoses...
Whatayaknow, this is going to work out! http://www.mijnalbum.nl/Foto-WGE7OB7V.jpg http://www.mijnalbum.nl/Foto-HYFYZAJK.jpg http://www.mijnalbum.nl/Foto-6MIYTSOF.jpg One obstackle less! :D |
Very nice! May want to add an extra layer of tape, that coolant gets pretty hot ;)
Originally Posted by 7moore7
(Post 326264)
Copper is 22 or 28 outside diam. Whatayaknow found a piece of a table-leg, stainless steel 25mm. Hooray! :) |
Finally have a complete cooling system, hope it is fully closed.
http://www.mijnalbum.nl/Foto-YRZCEYPP.jpg http://www.mijnalbum.nl/Foto-OQXHUJNL.jpg And someone from the dutch message board has made the electra for the fans. With 3 relais it swiches from serial (50%) to parallel (100%) when hot. http://www.mijnalbum.nl/Foto-OKCZLOKV.jpg http://www.mijnalbum.nl/Foto-QNGNHZDW.jpg Even fits behind the saddle! http://www.mijnalbum.nl/Foto-LQKL4FTM.jpg |
All that work, and still a stock R/R... :cry:
(Post 327008)
Not to worry mate, have my eye out for a mosfet one... R1 or such? Any other types I should be looking for? |
There is a whole list of compatible donors in the thread Mosfet Regulators, the how and the why...
