Coerce Belly Fairing?
Anyone have experience with the Coerce belly fairing from this company? I saw it in the "Old Yeller" gallery and IMO, looks better than the PB fairing from Wild Hair. I'm wanting to do a carbon lower fairing, front and rear fender. Anyone have pics of a red Hawk set up like this? Tax return money is in my account.
Thanks...
http://www.maxmcdirect.com/proddetai...=DA042CUCC1103
Thanks... http://www.maxmcdirect.com/proddetai...=DA042CUCC1103
I like the look of it. There were (are) a couple issues. One I talked about in the gallery was the front opening being too close to the header. I kept getting that burning resin smell. I also noticed the temp gauge went higher when I installed the lower. Cutting it open solved those problems. The other thing is the lack of a hole to check the oil level. If the light is right you can just see through a vent at an angle while holding the bike level crouching low... You get the idea. A hole needs to be drilled.
98ILVTR
Feb 2, 2010 12:06 PM
AZZKIKER
Jan 18, 2006 11:25 AM
