View Poll Results: VTROTM February 2015
kenmoore
66.67%
Wolverine
16.67%
MOONSTER
16.67%
Voters: 18. You may not vote on this poll
VTROTM Feburary 2015
Poll added
Picture (REQUIRED) 3 Max! Please limit picture(s) size to 1024 x 768.
Open to all Super Hawk Forum Members.
You are limited to 1 entry per month.
You can only nominate your own VTR. (projects, daily riders)
Candidates will be nominated up until the 15th of the month or when 15 nominees have been made, whichever comes first.
A poll will then be set up (on the 16th if less than 15 nominees)
for everyone to vote for VTROTM for that month and close on the last day of the month.
All participants who vote will get to vote only once per month so make it count!
Negative comments, criticism, harassment, and all around bad manner wont be tolerated.
If you have won VTR of the month, you cannot enter your bike for 12 months.
In the event of a tie, a 7 day poll will be set up to break the tie.
Rules subject to change / amendment at any time.
Description of a candidates bike should include the following If available:
owners name
year
color(s)
modifications
owners name
year
color(s)
modifications
Well here she is 1 year down the track and still more to do.
Haven't done much to her lately except ride because I enjoy it so much.
I have tried to be subtle with this bike and keep the overall look of a VTR however if you look closely there have been a lot of changes.
So the following has been done.
Replaced 99% of the fasteners with stainless Allen Head bolts including engine cases,polished engine cases with all logos removed.
Fireblade swing arm brace , coerce fork brace and sprocket cover, new 530 gold x ring chain sprockets and new Cush drive rubbers.
Modified Dan Moto Rear Sets.
Dynojet carby kit with a few changes to the jetting and no holes drilled in slides.
J.E high comp pistons, cleaned up the cylinder head porting, not that there was much to do, polished shot peened rods, H Power lightened Flywheel, electric water pump, 4 degree ignition advancer! removed anti rattle gears! remote vac lines for carby sync! removed PAIR system, removed lip in R/ H side exhaust header, projection racing high mount exhaust brackets with Mussari flange type cans in stainless with modded baffles. Cockpit mounted oil pressure gauge.
Hell braided brake lines all round with CBR 600 F4i calipers, foldable adjustable clutch and brake levers.
Modded front forks with springs and some mods to damper rod and valves, 5wt fork oil with decreased air cap, preload adjusters and as mentioned before the coerce fork brace. Removed the Nissin logos from calipers and painted calipers and fork legs black.
Hell braided clutch line.
Integrated LED Tail light and flush mount LEd fairing mounted front blinkers with new LEd flasher relay.
Reworked standard back shock .
Polished alloy brake reservoir caps all round.
Painted wheels white with polished lips and fitted all new bearings as well as new swingarm and suspension bearings.
04 R1 hugger fitted to braced swinger.
Mesh in air vents on front fairing as well as custom mesh headlight cover.
Bar end mirrors and Honda single seat cover.
I'm sure that I have missed a few things and there are a few more things waiting to go on including a HRC coolant bottle and a HRC rear brake master cylinder tube but that's about it.
This bike is my all time favourite and I just can't stop tinkering with it. It is more than it's sum of parts to me.
Oh well, guy can daydream can't he?
Just to make sure we have a poll...
2000 Hawk
D&D cut down slip ons
Ohlins shock
braced swinger
Race Tech .85's w/ Silkolene ProRSF 7.5wt
K&N
Helibars
ASV shorty c&b levers
F4i calipers + EBC HH pads
Goodridge SS front lines
Corbin
Bridgestone BT016f/023r
RK 530 16/43
Allballs tapered head bearings
03 R1 FH001 R/R
HaknSlash LED taillight mod
A-Tech carbon fender
TMB cct's
Powerlet outlet
Ram Mount for GPS
Vista Cruise control
Eastern Beaver headlight harness
Hella 100/55
Sorry about the ugly background on that last one.
2000 Hawk
Ohlins shock
braced swinger
K&N
Helibars
Corbin
RK 530 16/43
03 R1 FH001 R/R
TMB cct's
Powerlet outlet
Ram Mount for GPS
Hella 100/55
1998 SuperHawk.
This model was sold here as a Firestorm but this one is an import.
Its no Carpet Queen. It gets ridden everyday to work and does weekend pillion work (hence the seat which helps my partner a lot). And it does track days. Have one tomorrow.
FIL Mod.
Wrapped air box and fuel lines.
Water overflow bottle re-position
Crank breather to the rear fairing
Single throttle cable
Manual CCT
All ***** head bearings
CBR600 top yoke
Hot grips
DP HH+ pads
Braided lines
BT016s for track days and PR2s for road
Ohlins rear shock
Racetech fork springs and gold valves with secret rebound valve mod
Scottoiler
Speedo healer as I change gearing for track
Harris rearsets
Coil on plug
Much more I have forgotten
Coming is a swingarm brace when I can find somebody to weld it. Looking at getting a pillion only bike so then I will change the seat so I can run the pillion cover again and get rid of the pillion peg mounts.
Bit of a vid of her doing her thing, https://www.youtube.com/watch?v=t2-3...ature=youtu.be
FIL Mod.
Manual CCT
CBR600 top yoke
Hot grips
DP HH+ pads
Braided lines
Ohlins rear shock
Scottoiler
Harris rearsets
Coil on plug
Jedrek,
Thanks mate, there's still time to put yours on.
I want your pipes, they are the best I've seen..
I reckon with a quality set of carbon cans and your engine pipes the VTR would sound insane.
You have a few other bits I would give my left knacker for (very painful)that are unobtainium here in Oz.
I think it's a shame that there are not more bikes on here.
I'm sure there are bikes out there that have some rare bits on them.
I would like to see a bit of Moriwaki stuff on here.
Anyway, good to see some activity on here!
Ok, guess I'll throw my bike in on this.
2001 I bought new in 2002 after returning from being stationed in Germany.
Lists of mods:
Superbike bar
Pazzo levers
Spiegel brake/clutch lines
Moffett R/R
Corbin leater seat
Puig double bubble screen
Truckin's MCCT's
Undertail/tire hugger
Pirates adjustable pegs
Shaved rear pegs
Vortex +1 rear sprocket
Pair removal/blockoffs
Blue Flame EVO muffs
Blue Samco silicone coolant hoses
Speedo healer
Lists of mods:
Superbike bar
Pazzo levers
Moffett R/R
Corbin leater seat
Truckin's MCCT's
Shaved rear pegs
Speedo healer
I was just messin' around posting that picture! I honestly didn't think I would be placed in the poll. I didn't even abide by the rules. If possible, I would like to retract my entry and let MOONSTER take my place. Is this possible? His entry was posted in time, right?
One of the Mods (the very large weasel?) has already fixed things.
Aw, that's a shame .
I wanted to vote for Crux but I gave my vote to Moonster instead!
As I keep saying, I would like to see more bikes on here.
This is the source of inspiration where you see other peoples interpretations of the VTR and pic up ideas.
Mechanical or looks wise doesn't matter as long as it's something different.
Next month I would love to see a whole lot of bikes on here no matter what their state.
This post to me is an indication of the health of the site.
So many other forums I am on are dying a slow death and you can tell by the bike of the month posts.
Let's get this joint rockin!
Where do we draw the line kenmoore? Can I post up a pic of my old stock seat and exhaust and qualify it for VTROTM? Mori cams and belly pan? We need more than an engine and rear sets, or a few parts...
No way, I would have got at least one vote? Awesome
How about we have March our project bike month? I know projects can be entered anytime, but maybe having one month would get a bunch of projects entered without fear of loosing out to a nice looking complete bike? This is the reason I never entered mine. Well that, and it looks like crap haha.
Definition of project bike...well, how about, doesn't need to be running, but you must have at least an engine, frame and wheels?
