Project Make her Pretty
GSXR 1000. Easy way to identify it is the fork shafts. Only the 1000s have the black fork compression surfaces, 600 and 750 are silver. If you can see it from the side, the 1000 is the one that covers most of the clutch cover on the right side.
It's a ridiculous bike. First gear goes up to 85mph, will do pull up the wheel at 60mph without problems. And that's with the stock ECU programming, which pulls timing in the first four gears. I can only imagine how much worse it is with that removed.
If you browse my history, I have actually tried mounting a GSXR tail, that I got for free, in the past. The spacing issues between frame and subframe ended up being more complicated and I abandoned said project. And the tail pieces won't fit the superhawk subframe. I would need access to a welder, but it'd be too much effort to do the rear. The front wouldn't be bad
smack doogle
May 30, 2008 10:40 AM
EngineNoO9
Feb 20, 2007 08:24 PM
AZZKIKER
Feb 9, 2007 04:38 AM
