modding madness!
Old Oct 31, 2007 | 03:35 PM
hawxter996's Avatar
ole dirty bastard
modding madness!
my ? in progress
Attached Thumbnails modding madness!-angle.jpg   modding madness!-sickness.jpg   modding madness!-punishment.jpg
Old Oct 31, 2007 | 03:59 PM
MarineHawk's Avatar
Wow. That's just freaking cool looking.
Old Oct 31, 2007 | 04:32 PM
gboezio's Avatar
Wow, two thumbs up, love the underseat rad, the flames, the wheels, the long swing arm.
Nice work
Old Oct 31, 2007 | 05:07 PM
hawxter996's Avatar
ole dirty bastard
actually thats an underseat exhaust pipe for rear cylinder.
going to try a cbr600rr rad. in front.
front cyl. exhaust will wrap up above stator assembly.
its going to be 2 into 2.
Old Oct 31, 2007 | 05:55 PM
SlowHAWK's Avatar
Looking good...
I noticed it looks like you cut, flipped and rewelded the bottom rail of your subframe... Reasons why??? I'm guessing to make room for the exhaust? Highly interested as my new project will use a modified 2007 GSXR rear tail (I love the look)... so I'll be modding subframe as well... any suggestions?
J.
Old Nov 1, 2007 | 04:05 AM
hawxter996's Avatar
ole dirty bastard
Originally Posted by SlowHAWK
Looking good...
J.
i modded the subframe that way because visually it opens up that area.
gives a lighter look.
Old Nov 1, 2007 | 04:19 AM
SNGPerformance's Avatar
SNGPerformance is an unknown quantity at this point
Looks great . Good to see another fighter.
Old Nov 1, 2007 | 05:30 AM
hawxter996's Avatar
ole dirty bastard
not a fighter,going for more of a factory superbike kinda thing.
still have tons of work to do.
Old Nov 1, 2007 | 06:49 AM
RickB's Avatar
Looks great, like the flames!
Old Nov 13, 2007 | 05:08 AM
hawxter996's Avatar
ole dirty bastard
well took swingarm to powdercoaters.
as soon as ordered parts come in ,i can
start on initial assembly.
1st part being getting radiator mounted.
then bracing frame and powdercoating it.
need to do wheels also.
swingarm is going to be a textured black
with a red dyed kevlar carbon weave 600rr
hugger.
will post pics once started.
Old Nov 13, 2007 | 03:48 PM
Scrapyard's Avatar
Scrapyard is on a distinguished road
Very nice so far. Dig the subframe mod. Are you running a 929 swingarm? how much did you have to massage that, or did it bolt up?
Look foward to your progress. I'm half tempted to build another fighter with mine. Very inspiring.
Old Nov 13, 2007 | 05:50 PM
hawxter996's Avatar
ole dirty bastard
scrapyard,
swingarm is rc51 sp2.
it mounts as per stock but you need to mod shock mount.
see pics and you will get the idea.
you also need to fab linkage plates.
im sorry pics are in other post"other swingarms"
Old Nov 16, 2007 | 11:41 AM
hawxter996's Avatar
ole dirty bastard
as per request for other side
Old Nov 24, 2007 | 06:51 PM
hawxter996's Avatar
ole dirty bastard
well got swingarm powdercoated,installed new bearings and spacers.
everything lined up perfect.
now i need a chain tool.
Attached Thumbnails modding madness!-powderchain.jpg   modding madness!-powdercoat.jpg   modding madness!-nicky-mod.jpg
Old Nov 24, 2007 | 06:57 PM
superhawk22's Avatar
You can get a chain tool at CycleGear or any other parts place, if you do go to CG request the RK chain tool and NOT the MotionPro. They're the same price but the RK one is much stronger. Looks good BTW can't wait for you to ride it and tell me what effect the longer swing arm has on the handling.
Old Nov 24, 2007 | 06:59 PM
hawxter996's Avatar
ole dirty bastard
thanks for the heads up on the chain tool.
i imagine it would put more weight on the front end.
should cure it running wide under power.
Old Nov 24, 2007 | 07:09 PM
No problem, I was thinking with the shorter forks the swing arm might bring it back to where it was before.
Old Nov 25, 2007 | 04:20 PM
hawxter996's Avatar
ole dirty bastard
more pics.
Attached Thumbnails modding madness!-profile.jpg   modding madness!-overall.jpg   modding madness!-assembly.jpg
Old Dec 6, 2007 | 06:57 AM
hawxter996's Avatar
ole dirty bastard
here is the start of rad. work.
on the radiator i need to notch out the center top.
and have a radiator shop close it back up.
the reason for this is to pull it up higher to
clear the front wheel.
also have to mod the mounts to clear fork tubes.
Attached Thumbnails modding madness!-rad-fitup.jpg   modding madness!-fit-2.jpg
Old Dec 6, 2007 | 09:53 AM
SlowHAWK's Avatar
Whats your bar/turning radius clearence gonna be like with that thing? I know the RC front end cuts it down to begin with... looks like that rad will make it even worse... I guess if your track only, you'll be fine...
J.
Old Dec 6, 2007 | 11:24 AM
hawxter996's Avatar
ole dirty bastard
actually with the hose gone from under triples i have full turn radius.
Old Dec 7, 2007 | 02:13 AM
gboezio's Avatar
Sweet lookin, I love it !!
Old Dec 7, 2007 | 05:14 AM
hawxter996's Avatar
ole dirty bastard
thanks all!
once i get the rad.mounted i will have full turn radius.
the fork tubes will hit the frame. i need to work on
steering stops also.
im gonna add a couple diagonal braces to the frame
also.figure with stiffer forks and swingarm im gonna need them.
Old Dec 7, 2007 | 06:04 AM
SlowHAWK's Avatar
You must post up pics of how you finish up the rads as you move along...
J.
Old Dec 7, 2007 | 06:32 PM
trinity012's Avatar
I could not wait to see the whole puzzle put together but so far that is one hell of the job Sir.
Old Dec 9, 2007 | 04:19 PM
hawxter996's Avatar
ole dirty bastard
J.
this is a very rough sketch of what i am doing to rad.
basically notching out the center to raise it up higher
for front wheel clearance.
File Type: bmp
Old Jan 27, 2008 | 04:48 PM
hawxter996's Avatar
ole dirty bastard
Old Jan 27, 2008 | 04:51 PM
hawxter996's Avatar
ole dirty bastard
frame came back from powdercoater.
couldnt wait to test fit radiator.
just need to fab some brackets and finish sealing the rad.
waiting to coat the wheels and engine covers next.
Old Jan 27, 2008 | 05:32 PM
drew_c14's Avatar
Frame looks good. LOVE the radiator!
Old Jan 29, 2008 | 11:57 AM
cat0020's Avatar
El Cheapo
How did you seal the radiator after cutting away the top section?
