CB700SC Nighthawk
Old Jan 5, 2013 | 11:17 AM
spacetiger's Avatar
spacetiger is on a distinguished road
CB700SC Nighthawk
I've come over to the site from time to time to read and poach some technical info. I don't have a Superhawk, but have a distant relative from the Honda family tree; 1984 CB700SC Nighthawk. I am posting on this site since I used some VTR components to create the retro Nighthawk.
I have been working to bring it into the 21st century by upgrading the tires, suspension, and braking. For my riding envelope, it has enough peak HP for now.
I have largely finished the wheel swap, tire upgrade suspension changes, and brake swaps. Once I get the swingarm back in (today?), the bike will be rideable again. I have the chin spoiler and factory (CBX) bags to integrate in before taking on a cosmetic redo next winter. I will leave her cosmetically a bit rough this riding season so I can ride her this coming season.
Major changes:
Wheels: 2010 NT700V 17" front & Rear
Tires: Michelin Pilot Road 3
Front fork: VTR1000 fork lowers, custom length stanchions (NH needs longer forks), VFR cartridges; I used a VTR front fender and extender)
Rear shocks: Kawasaki KZX1000 (KYB manufacture)
Front brakes: VTR dual 4 pot fixed calipers with offsets to accommodate 316mm ST1100 PanAmerican discs.
Rear brake: 2001 Triumph Trophy 1200 rear caliper and axle bracket squeezing a Honda blackbird 256mm disc.
There are lots of other bits and bobs from a lot of other bikes, but they generally go together to look factory.
A pic of the bike before I worked on moving the lower shock mounting points...
Jerry
Attached Thumbnails CB700SC Nighthawk-.-1.-bike-pre-ride_right.jpg_thumb.jpg
Old Jan 5, 2013 | 12:08 PM
JN607's Avatar
SHawk Member
JN607 is on a distinguished road
Damn, that's a clean bike. Looks factory.
Old Jan 5, 2013 | 12:12 PM
Good looking bike
Old Jan 5, 2013 | 12:36 PM
Nice work this is actually very well build bike to begin with, for the era! In fact better then the later 90's models which Honda tried to cut on costs and make it as basic as possible.
Hydraulic valves makes the motor bullet proof and lots of torque at low end for.
Here is what I did to my second bike which is also NH but a bit later model, maybe you can get some additional ideas:
Cheers
Old Jan 5, 2013 | 01:34 PM
spacetiger's Avatar
Cheers
What wheels did you use?
Did you consider going to fixed calipers?
Nice bike, much edgier than the original.
Jerry
Old Jan 5, 2013 | 02:10 PM
Jerry
Front wheel is CBR600 F2 had to keep the speedo' cable.
These calipers working better then I expected, if you remeber, this model came with single rotor in the front, this setup bites hard.
The rear is 6" CBR900 wheel, can't remember the year
Old Jan 5, 2013 | 03:46 PM
The '84 through '86 CB700SC came with dual discs in front and drum in rear (shaft drive). With the stock 16" wheels, it was easy to lock up the front brakes.
The front rotors in spacetiger's photo are way larger than stock.
These look like the old CBR1000F rotors
Old Jan 5, 2013 | 06:21 PM
HRCA#1's Avatar
Cheers
This is actually the first generation NightHawk! It's an aircooled chain drive 650 or 750 circa 81/82. They were usually Cobalt Blue with a Chrome Graphic on the tank. Only built for 2 or 3 years.
The 84 thru 86 were completely different motors and as already noted had hydraulic vavles and shaft drive. Good bikes I had a red and black one, learned to hate 16 inch front wheels!
Old Jan 5, 2013 | 06:30 PM
Are you referring to spacetiger Bike? I thought it is the same motor as the later 700S... Honda already had the Hydraulic valves in 84 in the 650NH, at list to my memory.
Old Jan 6, 2013 | 03:50 PM
spacetiger's Avatar
Got the shock lower mounting points moved forward about 2 inches using an 87 VT700 Final drive and modified the right side using part of a PC800 swing arm.
Relocating the lower shock mounts + slipping the fork down 0.5" got my rake and trail numbers where I aiming:
Stock: 30 degrees and 4.8 inches
New 24.7 degrees and 4.0 inches.
I'll take it out sometime this week if I can get home early with daylight.
Jerry
Attached Thumbnails CB700SC Nighthawk-4.-rake-vs-trail.jpg   CB700SC Nighthawk-84-nh_s_final-drive.jpg   CB700SC Nighthawk-86-vt700-final-drive.jpg   CB700SC Nighthawk-7.-comeing-back-together-5.jpg   CB700SC Nighthawk-7.-comeing-back-together-8.jpg
Old Jan 6, 2013 | 04:40 PM
Jerry
Looks like it's well balanced mate, should be easier to lean into turns with this setup.
Cheers
Old Jan 6, 2013 | 04:55 PM
Hopey's Avatar
Hopey is on a distinguished road
Thumbs up Awesome Bike
Spacetiger,I had 3 buddies with Nighthawk 750's(in Canada)They were tough bikes those guys ran them hard!One of the guys had big carbs and a supertrapp it sounded great and if I'm not mistaken he machined (thinned)a second spring for the clutch,to stop it from slipping.Thanks for the flash back !you're doin that bike proud!!!
Chrisguilday
Sep 8, 2015 05:28 PM
Bradluck
Feb 13, 2015 06:39 AM
KrakenNuts
Feb 25, 2014 08:34 AM
flyjay66
Feb 22, 2009 07:54 AM
