What Bearing to use for Front End
Old Jul 15, 2009 | 05:07 PM
calitoz's Avatar
Escape Reality
Red face What Bearing to use for Front End
Hey Guys,
I am embarking on the front end swap right now and need some help on bearing selection:
Currently there is a beveled bearing on the triple which I am trying to remove. In the process without a Bearing extractor, I damaged the bearing. I initially try to use the beveled bearing as is but it did not work as it did not sit right since the Hawk uses standard round bearings at the bottom.
2 Questions:
1. How am I going to extract the existing bottom bearing.
2. What size and where can I purchase the right bearing for the conversion. The stem seems to be 30 mm at the top. I assume it is as well at the bottom. See pictures.
Help
Thanks for the help
Old Jul 16, 2009 | 06:01 PM
calitoz's Avatar
Escape Reality
Nevermind
I finished it
Old Jul 16, 2009 | 06:34 PM
Nice, what forks are those?
FYI: too late now, but I got tapered bearings from allballs.. Just told them what bike it was and what triple I was using. I had a local shop remove the old ones and press on the new ones for me.
Old Jul 16, 2009 | 07:03 PM
Lou, if you contact all-ballz they can hook you up with a match given your switch. They can get you fixed up.
millerwl71
Jul 27, 2012 07:18 AM
uchi
May 8, 2011 07:34 AM
mboe794
May 23, 2010 06:05 PM
mikstr
Feb 15, 2007 04:14 PM
Speed_Demon
Dec 28, 2005 06:57 PM
