What Bearing to use for Front End
Hey Guys,
I am embarking on the front end swap right now and need some help on bearing selection: Currently there is a beveled bearing on the triple which I am trying to remove. In the process without a Bearing extractor, I damaged the bearing. I initially try to use the beveled bearing as is but it did not work as it did not sit right since the Hawk uses standard round bearings at the bottom. 2 Questions: 1. How am I going to extract the existing bottom bearing. 2. What size and where can I purchase the right bearing for the conversion. The stem seems to be 30 mm at the top. I assume it is as well at the bottom. See pictures. Help http://img404.imageshack.us/img404/1...c01130b.th.jpg http://img81.imageshack.us/img81/562/dsc01131a.th.jpg http://img200.imageshack.us/img200/6...1132vsx.th.jpg Thanks for the help |
Nice, what forks are those?
FYI: too late now, but I got tapered bearings from allballs.. Just told them what bike it was and what triple I was using. I had a local shop remove the old ones and press on the new ones for me. |
Lou, if you contact all-ballz they can hook you up with a match given your switch. They can get you fixed up.
