tl1000 front end
Old May 21, 2010 | 05:02 AM
twidge's Avatar
twidge is on a distinguished road
tl1000 front end
hi all
has anyone used their vtr front wheel when doing a suzuki front end swop?
i can find some wheel bearings with a 25mm inner diameter and same 42mm outer but they are only 9mm wide instead of 12mm. seems to me to be a bit iffy to use these or is there something else i should be doing?
many thanks
twidge
Old May 21, 2010 | 05:11 AM
Well, in theory if you use a set of custom wheel spacers or a longer spacer/tube in the middle and the bearings are otherwise suited as wheel bearings it shouldn't be a problem... The important part is that the wheel is clamped as a "solid part" from spacer to spacer between the forklegs... And that it's in alignment...
Have you checked the alignment on the calipers/discs? Do these match up on the TL forks with the VTR wheel?
BTW, there haven't been anyone else doing a swap with a TL front AFAIK...
Old May 21, 2010 | 07:27 AM
Galaxieman tried to do a TL swap and ended up selling those forks and getting GSXR ones instead.
https://www.superhawkforum.com/forum...ad.php?t=19702
Old May 24, 2010 | 05:02 AM
twidge's Avatar
many thanks for your pointers tweety and lazn. i like the idea of modding the stem bearing i,ll let you know the results of everything but it may take some time as i will be riding my bike during the short summers we get here.
Quin
Jan 14, 2012 11:52 PM
swordfish
Apr 15, 2009 03:16 PM
klicks
Feb 25, 2008 04:23 PM
OldHawkNewB
Mar 19, 2007 04:17 PM
mdbuehler
Mar 26, 2006 01:31 PM
