tl1000 front end
tl1000 front end
hi all
has anyone used their vtr front wheel when doing a suzuki front end swop?
i can find some wheel bearings with a 25mm inner diameter and same 42mm outer but they are only 9mm wide instead of 12mm. seems to me to be a bit iffy to use these or is there something else i should be doing?
many thanks
twidge
many thanks
twidge
Well, in theory if you use a set of custom wheel spacers or a longer spacer/tube in the middle and the bearings are otherwise suited as wheel bearings it shouldn't be a problem... The important part is that the wheel is clamped as a "solid part" from spacer to spacer between the forklegs... And that it's in alignment...
Have you checked the alignment on the calipers/discs? Do these match up on the TL forks with the VTR wheel?
BTW, there haven't been anyone else doing a swap with a TL front AFAIK...
Galaxieman tried to do a TL swap and ended up selling those forks and getting GSXR ones instead.
https://www.superhawkforum.com/forum...ad.php?t=19702
many thanks for your pointers tweety and lazn. i like the idea of modding the stem bearing i,ll let you know the results of everything but it may take some time as i will be riding my bike during the short summers we get here.
mdbuehler
Mar 26, 2006 01:31 PM
