Thermostat Hoses... again
Old Jan 23, 2012 | 01:08 PM
Squid's Avatar
Here I go again, I removed the PAIR, EVAP, and CAV systems off my bike and have figured all the lines I need to cap and plug BUT, The coolant line that is on the T-stat that faces aft just above the Temp Sensor.. uh, I dont know where it went. I have followed the manual and browed on here for a good while this morning and I dont know where I have gone wrong. Any help. Thanks.
Old Jan 23, 2012 | 01:11 PM
That one goes no where..... if you look it is blanked off (the hole isn't drilled)
Old Jan 23, 2012 | 01:22 PM
Squid's Avatar
WOW, just wow. Thanks for that help. I really cant belive that I didnt remember that from last time, or take note of it this time, or even look at the damn fitting. Ha, and I work on F-18s... Somthing wrong with me. Thanks!
Old Jan 23, 2012 | 01:26 PM
They designed that part on April 1st
Old Jan 23, 2012 | 01:47 PM
Squid's Avatar
Ha! Yeah, they got me... twice.
Old Jan 23, 2012 | 02:03 PM
Well it would have been worse if you did find a hose to hook to it.....
No worries but you do have to live with the fact an old jarhead pointed it out to you....... damn squids....
It just one of those cost cutting things, Use the same basic casting for as many parts as possible. the same reason for the faux CCT mounting points on the cylinders.
Old Jan 23, 2012 | 06:37 PM
Squid's Avatar
Ha Ha, yeah... From the min I joined this site I wanted to try and keep an even playing field on the ol' navy vs marines... Dropped my guard and you caught me with my pants down . Thanks for helping me out with that. I was racking my brain, I read the Carb and coolant system removal and install 3 or 4 times, looked thu older posts and couldnt find anything out on it. Now I know why.
Old Jan 23, 2012 | 06:42 PM
Squid's Avatar
I used your build thread to look for that non existant hose and it seemed to me that you took a pic detailed pick of everything other than the t-stat. Where were you man? . Everytime I look at your build it makes me want to tear into mine and Just Do It.
Old Jan 23, 2012 | 07:51 PM
I'd always wanted to do something like the build too. The real "kick it into gear" moment was when I found a crack in the frame and people on the forum tried to convince me that this was dangerous, or potentially unsafe or something nonsensical like that and I had to take it apart to get to the frame...
Moral of the story is take a hammer to your frame, and then you have to take it apart!
A thermostat pic from that bike may have messed you up anyway... I have the housing mounted 180 degrees for the hose routing
Old Jan 23, 2012 | 09:18 PM
Squid's Avatar
Nice moral. unfortunatly I think riding weather is just around the corner, Im having enough trouble deciding if i REALLY want to send my forks and springs out to get re-valved. When It rains weeks on end its hard to not have the bike ready for a day with ONLY 40% chance of rain . I just need another bike to be my project.
VTRFan
Jul 23, 2007 07:07 AM
beesfan
May 17, 2007 12:22 AM
superbling
Aug 27, 2006 02:56 PM
cat0020
Jun 23, 2006 05:44 PM
chickenstrip
May 2, 2006 03:04 AM
