Originally Posted by calitoz
(Post 278707)
:wtf2:
And yeah, it might have been vague... But if you are "old enough" on the forum it's fairly logical... Trace the origins of the bike that 2whltuner posted images of, and you find that it's the very same bike built by Brian Light... And that is either the first bike with an SSS conversion, or at the very least the first documented build... And it predates me registering on this forum by a few years, having been sold, re-sold and discussed many times over... Hence my comment on "full circle"... |
(Post 278712)
I'm guessing he was responding to my post...
And yeah, it might have been vague... But if you are "old enough" on the forum it's fairly logical... Trace the origins of the bike that 2whltuner posted images of, and you find that it's the very same bike built by Brian Light... And that is either the first bike with an SSS conversion, or at the very least the first documented build... And it predates me registering on this forum by a few years, having been sold, re-sold and discussed many times over... Hence my comment on "full circle"... No tweety. It wasn't direct at you. I knew exactly what you meant.... |
Well... quoting is a bitch sometimes... I meant ima98chickenhawk...
yeah tweet sorry. it took me finding images of both the swing arms(vfr750 and 800) to understand what you meant by different configuration, now that i have seen them i get why it seemed like a sufficient answer because it is blatantly obvious. i didn't know what i was looking for so the responses seemed like ya'll were kinda blowin me off. my bad dude.
3 Attachment(s)
I think the bike looks better now...... But I might be jaded.
750 arm below
http://hawkworks.net/VFR750F-1997-fi...l/swingarm.gif 800 arm belowhttp://cdn.partzilla.com/diagram/hon...CWAF/2600A.png |
(Post 295279)
The whole fairing is Mario Nava carbon fiber. If you look closely the upper isn't stock either. It has different lines, less curvy than stock. This lower wouldn't mate up to the stock upper. Slightly more italian to me.
(Post 161546)
Step 4: (Linkage Plate and dog bone)
The shock linkage plate and the done bone must be fabricated. I am going to post Brian’s drawing along with the dog bone. This is required since the VTR dog bone cannot be used. http://img166.imageshack.us/img166/2250/platepw9.th.jpg http://img153.imageshack.us/img153/7...0714er8.th.jpg http://img525.imageshack.us/img525/8...2141525.th.jpg My Firestorm - SuperHawk Forum how long does it need to be? if anyone knows it would be greatly appreciated. |
Not sure how this thread got resurrected but I actually own the original of Brian Lights SSS bikes. With all due respect, that setup wasn really not well built and was in the process of failing at the aluminum triangles which already had elongated holes from not being strong enuff to begin with.
I have a friend who is a bikebuilder with a machine shop and when I took him the bike to do some custom header work (I was installing a penske and needed clearance) he said he didnt want me to ride the bike due to the linkage failure. He rebuilt the whole thing in a non failable sort of way and its way better now. I can take pics if anyone wants them. PM me |
(Post 334882)
(Post 334882)
(Post 334882)
I have a friend who is a bikebuilder with a machine shop and when I took him the bike to do some custom header work (I was installing a penske and needed clearance) he said he didnt want me to ride the bike due to the linkage failure. He rebuilt the whole thing in a non failable sort of way and its way better now. I can take pics if anyone wants them. PM me perhaps it is the quality of the aluminum itself is the problem. As with all custom fabrications, the end result quality is highly dependent on the materials used and skill set. OEM r&d is what we sometimes fail to respect. As for the dog bone, I will measure when I get back home. On that note, I would suggest instead of a fixed length, you should consider making adjustable one instead. A design similar to adjustable camber arms for cars. This will allow much more flexibility. |
(Post 334905)
After measuring my set up; on center, it is 4.5 inches. I would again suggest that you fabricate an adjustable link so that you can dial in the exact height that you want. If I had to do it over again, I would do exactly that. GL
thank you! im going to start measuring the adjustable ones i have available at the shop.
(Post 295279)
I do miss the old girl but I've moved on to several other bikes/projects in the mean-time. Thanks for sharing!! BLIGHT |
Yeah, still alive. CBR1000RR front end with apex bars. Not my daily rider, its just too nice
(Post 295279)
(Post 347267)
Edit: Wait... I just saw someone else with over 5000 posts!!! Wow, lots of free time there I guess. Northern climate perhaps?... perhaps not much time to actually ride a motorcycle? hehehe.... |
3 Attachment(s)
(Post 295301)
The upper is 100% fiberglass. The lower has a small CF panel on the very bottom edge, standard FG on the upper portions. The same goes for the rear seat section, the CF was only in the aft tail piece, although I see the OEM SuperHawk seat in your photos. Mario Nava and I discussed this by cellphone while he was driving before I placed the order... it was a way to reduce cost and still look 'racy'. BTW, Mario based the lower design on the CBR900RR lowers. It's a pretty close copy, and good looking. Your bike still looks good overall, but frankly I'm not a fan of the white tape (or paint) sections... just my opinion though.. I preferred my original red and contrasting carbon fiber design, which are similar to Mario's designs. Hope you are enjoying the bike though!!. It really ran like a monster when I sold it to Eric in VA! It looked like this when it shipped out: Attachment 23993 Attachment 23994 Attachment 23995 Also, sorry to hear you are having trouble with the triangular plates... I pulled them after 2000 miles to inspect them and there was no visible wear. Not sure what happened to them after the bike was sold... maybe the subsequent owners were 300 pounders, or the East coast roads were really tough. Dunno. The plates I made were 6061-T6 aircraft aluminum, and a bit thicker than the OEM Honda alloy plates. Still, folks anyone considering a conversion... good advice to make the triangular plates from steel for your conversions, as an added level of safety. Many recycled metal stocks come from China or wherever in recent years, and may not be quite as strong as expected. Cheers, BLIGHT |
(Post 161546)
1 - VFR 800 rear swing arm. VFR 750 swingarm will NOT work because the mounting scheme is completely different. I used a 1999 VFR 800 unit.
Originally Posted by blight
(Post 347296)
Cool... wow, 2100 posts? Pretty amazing....you must be the SuperHawk expert here!
Edit: Wait... I just saw someone else with over 5000 posts!!! Wow, lots of free time there I guess. Northern climate perhaps?... perhaps not much time to actually ride a motorcycle? hehehe.... When I made my triangles for the swap I did to SP1/SP2 swingarms, I opted to use steel plates for the exact reason that aluminium plates wouldn't really last well... One thing to note, while you may have selected a nice grade of alu, and a nice thickness, a non OEM plate pattern might put larger than desired load on the holes as a result of the goemetry and mechanical advantage it creates... I found that some variations of hole pattern that was very, very similar produced very different forces when calculated and very different feeling as far as suspension when i tested them... |
(Post 347296)
Anybody send me big photos from the first page, please. My mail 750rs@mail.ru
Hey yeah Im in the process to this thread helped alot. It would save me some time though if I knew the exact size of the triangle deals and do I need a custom dog bone?... or do I get a adjustable dog bone? Never even heard of one but sounds cooool.
Thanks for any help Im literally mid way in right now |
Hey, does anyone know if the newer vfr swing arms fit as well?
誰知道怎麼才能看到圖片?
What picture?
| All times are GMT -7. The time now is 04:19 AM. |
