radiator cap cross reference
Old Sep 19, 2011 | 10:56 AM
ascothawk's Avatar
ascothawk is on a distinguished road
An alternate to oem is Stant #10233 available at Advance Auto for 7.49. 1.1 bar=16lb. I found my gasket was split on the original cap while I was changing coolant. I also found my overflow bottle was plugged. I unhooked the overflow hose to drain the bottle and nothing came out. I used my compressor to clear the blockage while flushing the bottle with a hose and let the sediment float out.Just wanted to share this because the overflow function probably rarely gets tested.
Old Sep 19, 2011 | 11:08 AM
sheldonsl's Avatar
That's good info. Thanks.
Old Sep 19, 2011 | 12:48 PM
mboe794's Avatar
The parts stores around here carry a brand called Motorad. I have been using one for a while now and am happy.
fyi.... Deionized water destroyed my stock one. Or at least that's my best guess as to what happened. Something about the PH.
jerryh
Jul 3, 2014 05:32 PM
residentg
Oct 5, 2010 07:27 AM
mikstr
Dec 14, 2009 06:04 PM
A Team
Jul 16, 2007 07:05 AM
Chitownson
May 28, 2007 11:08 AM
