Petcock fix with pics
Old Jul 7, 2010 | 01:56 PM
  #31
I still don't see the upside of using WD40 on rubber parts. Again, I use carb spray to help remove and install fuel lines. For just about anything else, a little shot of silicone spray works. I do keep a couple of cans of WD40 for light lubrication, freeing up parts and cleaning tools.
As for composition of different types of "rubber"...I've seen a number of carbureted cars/trucks where the PCV hose was replaced with a length of heater hose. The heater hose softens from the exposure to hydrocarbons and then collapses, causing the engine to leak oil from the seals.
And one time my students were driving a Chevy pick-up into the shop to do a brake job, when they smelled gas. Someone had replaced the fuel line going to the carb with vacuum hose, which had softened and split.
And I've seen a number of v-belts ruined by WD40...use silicone for squeaky v-belts, after checking for glazing and adjustment.
Old Jul 7, 2010 | 02:08 PM
  #32
Originally Posted by kraher
I have been at work for a few hours, but before I left the petcock had still not released. I left it overnight.
The thing is, unless my vacuum port is buggered and only flowing one direction this makes perfect sense to me. There is no way for air to get back in and allow the spring to push the diaphragm back.
This problem should be possible to solve.
1. Disassemble petcock to make sure spring is on vacuum side of diaphragm. Make sure diaphragm is intact.
2. Make sure vent is open and clear, no obstructions.
3. Make sure the vacuum hose is pulling good vacuum and has no obstructions or kinks. There could be a chunk of hose that broke loose inside that is acting as an internal check valve.
4. Double check to make sure vacuum is hooked up to the correct port, the one facing sideways towards the left side of the bike. Vent port faces down.
Another possibility is that the actual mechanical valve, not the diaphragm, is sticking. I haven't had one of these apart, so I don't know exactly what part moves to open and close fuel flow.
Old Jul 7, 2010 | 07:42 PM
  #33
kraher's Avatar
kraher is on a distinguished road
All of the above are non issues. I said earlier that the bike runs flawlessly.
When I first saw the problem I ordered a rebuild kit for the petcock and completely rebuilt it. It functions perfectly in that a vacuum definitely opens it, and it will definitely flow fuel...the problem is the closing.
It has now been about 24hrs since the vacuum was first applied and the diaphragm has yet to "pop" back out.
Here is the current test (in progress):
Sadly, I did not take a photo with the diaphragm "out". You will have to take my word for it that it is currently sucked in and the vacuum was momentarily applied about 24hrs ago. You can also see that both the vacuum and vent ports are clear. To be clear, before I reassembled the petcock I could blow air in both directions through the vent but only the one direction through the vacuum port.
Unless someone can tell me that the vacuum port should flow both directions I see nothing wrong with the above...quite simply there is no way for air to get back into the vacuum side. Honda apparently went to a lot of effort to give the illusion of a vacuum petcock when in reality it is a gravity drain
Old Jul 7, 2010 | 08:33 PM
  #34
kraher's Avatar
Based on a PM from a helpful member, stating that the vacuum port was 180deg rotated I decided to disassemble the petcock and rotate it.
Not surprisingly it does not appear to have improved the operation of the petcock.
It did give me an opportunity to snap a pic of the diaphram in the "out" position though:
Old Jul 12, 2010 | 10:14 PM
  #35
storm_rider's Avatar
I received my rebuild kit today. Shouldn't be any problem if it's re-assembled exactly as found. Are you sure you have all the right components as shown here?
Old Jul 13, 2010 | 01:14 AM
  #36
revhead1957's Avatar
revhead1957 is on a distinguished road
Kraher, I have read and reread your response to vtrsurfer and can't understand it. He is asking you to check the position of the spring and that the ports are not blocked.
This is a simple assembly, the valve is held open by vacuum only. If it stays open, something is not right.
Is it possible that the valve was assembled incorrectly before you disassembled it - i.e. is it possible the previous owner/service person stuffed it up?
Old Jul 13, 2010 | 12:09 PM
  #37
As for you only getting air to pass through the vacuum port in one direction, there may be a check valve in the vacuum port, since at full throttle vacuum is zero. Therefore at extended full throttle, you would run out of gas in the float bowls if constant vacuum was required to keep the petcock open.
All I know is that during the several (almost 10) times I've pulled my tank, I've never manually turned off the petcock. I just put it on my rear stand and pull the tank. I've never had any gas spill out of the tank, only the gas in the lines to the carbs spills out.
Old Jul 14, 2010 | 06:59 PM
  #38
kraher's Avatar
Nope, I tried to get the above kit but my Honda dealer could not get it apparently. Maybe only available in the US?
I instead ordered an after-market rebuild kit that included all of the rubber bits as well as the spring.
Can you pass air through both directions on that vacuum port?
Agreed! Very simple assembly. I have a very simple problem too. If I could get the above kit it would include a new vacuum port which would likely solve the problem.
Not entirely true, if there was no vacuum at WOT then no fuel mix would enter the engine and it would stop. I will agree that the vacuum is considerably less at WOT than idle. I can tell by sucking on the port that the amount of vacuum required is very little.
There is some form of mechanism on the vacuum port (it is not just an open hole) of the back plate, I was wondering if it was just something that forced the pressure to equalize slowly in order to avoid momentary blips in fuel flow between intake strokes? But in leaving the thing on my desk for two days and the pressure failing to equalize that is not the case.
I do not think this mechanism is a check valve as there is no other way for air to get back into the petcock and equalize the pressure and stopping flow.
The back plate has failed, I have been using the bike with it as a gravity drain. Not the best practice but I am tired of thinking about it. If someone could confirm for me that air should flow both ways through that port then I would just buy a new or used petcock and be done with it.
Old Aug 27, 2012 | 07:03 PM
  #39
kardiac996's Avatar
I removed my PAIR system and no longer have a hose for the Tank Vent seen below Unknown #2 port next to drain inlet. Does this port remain open or should it be capped. Im not so sure I understand its purpose.
Any explanation would be awesome
Thanks
Originally Posted by minispeed
I was having some idle and running issues and did a search. A few other posts explained the same issues that I had and the most recommended fix was a tear/leak in the petcock diaphragm.
The issues I had were
  • stalling out at idle
  • while cruising at 4-5k rpm I might lose power, be able to cruise but not accelerate more than a smart car with two fat men in it.
  • rev it up high in neutral and it would go no problem but not sound that great.
  • running rich
And the final one was the massive fuel leak on the garage floor. This problem happened just before I removed the tank and I had the other problems for quite a while before the leak.
The new parts, $45 Canadian from Honda, took 1 day to get them
After you remove the seat and lower bolt from the tank put a towel over the metal bracket and seat area so you don't scratch your tank while flipping it upside down like I did.
Petcock on the tank, at the front is a square part that you turn to cut off the fuel prior to taking off the hoses. When you remove it with the two Allen bots be careful not to pull or rip the fuel filter and O ring that attaches to the bottom
This is the part that gets replaced. Simply remove the four screws. Pay attention to the orientation of the openings. The kit comes with a new spring to go between the two plates.
Back in with all the hoses reconnected.
2 hoses go to the carb, they both have the clips on them and due to the bends can't be mixed up.
From what I read about the hook up it appears as my petcock was hooked up wrong so I would like someone to verify that this hook up is right. Also if anyone knows what the three unknown hoses are leading to please add that info.
Unknown # 1 has a small clip on it and goes to the side vent of the petcock. The bottom vent on the petcock vents to atmosphere. Here's a better pic of that hose
Unknown #2 goes to the far right side. *note* this should be the last hose removed and the first put back since it will leak fuel through the opening. This hose is long enough to leave it on while you flip the tank.
Unknown #3 goes to the larger opening beside #2, it's the only hose that will fit that opening.
Since #2 and #1 appear as they will fit either vent tie them off to their respective sides after removal so you don't mix them up.
Old Aug 27, 2012 | 08:01 PM
  #40
saige's Avatar
the boss
the very bottom nipple on the petcock doesnt get blocked off.
the nipple on the back of the petcock that is sideways has a hose that goes to the rear head,this is the vacuum line to operate the petcock.
on the left side of bike,right underneath to the left of the carb boot,should be a nipple,it should have a hose.if it doesnt,then you need to put a hose to it to connect to the back of the petcock.
Old Aug 27, 2012 | 08:23 PM
  #41
kardiac996's Avatar
yeah after i wrote this i did some research and opened my eyes lol. It was dark out so... but no excuse the line was there it just fell flat with my rear spring so i was not able to see it. I re assembled went for a 10 mile test ride and im good to go.
No more squid like posts from me haha and I also realized this thread was way old lol. my apologies with this as well!
Old Aug 27, 2012 | 09:13 PM
  #42
saige's Avatar
the boss
lol,all is good,that little hose has got us all at one point or another.
Old Oct 23, 2012 | 08:27 PM
  #43
Third Echelon's Avatar
Third Echelon is on a distinguished road
It just got me an hour ago
Old Sep 13, 2014 | 07:14 PM
  #44
Maybe I should move this thread to the knowledge base? Stick?
Old Sep 13, 2014 | 09:21 PM
  #45
It would make sense. Do it
Old Apr 4, 2015 | 01:03 AM
  #46
Cadbury64's Avatar
VTR virgin
I had a problem with a fuel leak through the carbs with the bike parked. Having read the posts above (especially poor Kraher) I think I can add a little detail. There certainly is a one-way valve built into the vacuum fitting, and my one showed the same symptoms as Kraher, the diaphragm was in good order and was able to open the fuel flow, but it then stayed that way for a long time and would be the source of my carb leak (a non-sealing float valve must also be in the loop but I haven't gone there yet). I attempted to diassemble the one-way valve by trying to lift out the small silver fitting inside the body, but couldn't hook it out, but I did succeed in making it work properly i.e. releasing the vacuum slowly and allowing the fuel valve to close.
Old May 8, 2015 | 09:19 AM
  #47
996thehawk's Avatar
996thehawk is on a distinguished road
Does anyone know if this part number will work on a 98? When I search for the part number the listings say 99 and up.
Old May 10, 2015 | 07:35 PM
  #48
Cadbury64's Avatar
VTR virgin
The fuel petcock assembly is the same for all the 17L tank models. The 19L tank models use a different tap I think.
Old May 11, 2015 | 03:02 AM
  #49
Cadbury64's Avatar
VTR virgin
Answering this post earlier today prompted me to head for the garage and actually install the new diaphragm parts. So I can definitely confirm that the 16953-MLO-034 part was an exact replacement for the parts in my 1997 model.
Old May 15, 2015 | 09:54 AM
  #50
Hangfly's Avatar
http://www.ebay.com/itm/Honda-16953-...24b9c8&vxp=mtr
Pretty good price on these from PARTzilla
But this seller may be a better bet:
http://www.ebay.com/itm/Honda-Fuel-P...f9eb49&vxp=mtr
Mine is working ok now with (half the parts from) an aftermarket kit . But keeping an eye on it.
Old Mar 26, 2016 | 07:04 PM
  #51
Chris03653837's Avatar
Chris03653837 is on a distinguished road
Smile does anybody know the name of this hose and connector and whre I can get, thank you.
Old Mar 26, 2016 | 07:43 PM
  #52
Chris, those two hoses aren't actually needed. I and several others have run our carbs without those two hoses. With the hose gone, point the black plastic nipple downwards. However, if you feel that you need the hose, you can pick some up from your local hardware store or hobby store. If you feel that you need to have hoses from Honda, check Partzilla.com
Old Mar 26, 2016 | 07:52 PM
  #53
Are you sure? They seem to be part of the vacum system.I am also missing one of the tips.
Old Mar 26, 2016 | 08:18 PM
  #54
Your picture doesn't show up. You must go to dropbox to view it. The picture shows two lines that are highlited with yellow, correct? Those are two seperate lines. They do not connect the two carbs together. Each of those black nipples vents to atmosphere.
Old Sep 9, 2018 | 07:26 PM
  #55
FireHawk996's Avatar
FireHawk996 is on a distinguished road
Ok, I know this is a very old thread but I really need some help here. My 98' Superhawk has had every fuel issue known to man and I am desperate to get this bike fixed. My gas turned to tree sap (still not sure how this happen), causing one of my float values to be stuck open, flooding my engine with gas AND leaking all over the floor in my garage (causing the wife to be irate). I have since cleaned the carbs (also had a torn diaphragm so had to replace that). I have cleaned the carbs on this bike many times, but this time I picked up a gallon of Berryman's and soaked all the metal only parts. The carb that really failed I let soak for about 4 hours which is the maximum recommend time to let anything soak. everything looks very new and shiny now but, then I discovered my petcock diaphragm is shot. I have replaced this before without any issue but this time something is wrong. After putting the petcock back together, I attached a piece of scrap vacuum hose and sucked on the port for vacuum. The diaphragm opens and closes but does NOT make full contact with the open the fuel comes out of. I can hold it up to the light, look through one of the fuel ports and barely see a gap to the to the other fuel port. Has anyone had this issue? This bike is costing me so much money, I just want to get it running again and sold. In the past year I have spent money on a pulse generator, carb. parts, new battery, my brake lever snapped, and now this petcock issue. I have never abused this bike in the 15 years I have owned it, but this is ridiculous of all the stuff breaking at the same time. PLEASE HELP!
Old Sep 9, 2018 | 07:59 PM
  #56
superhawk138's Avatar
superhawk138 is on a distinguished road
I have that issue with a ebay rebuild kit. Opens fully but doesn't seem to close all the way maybe 1/16" gap left from fully sealing and takes a while to do that. The spring doesn't seem to have the oomph to close it fully.
Old Sep 10, 2018 | 06:27 AM
  #57
And you know know why I only use the pattern after market petcock kits on my junk trainer bikes.
Get a OEM repair set COVER SET, PETCOCK 16953-ML0-034
$29~33 retail online parts places, likely double that at your local dealer...
Amazon and Ebay in the $45 range
Old Sep 10, 2018 | 05:53 PM
  #58
COVER SET, PETCOCK
16953-ML0-034
Much appreciated! I am guilty of buying the aftermarket kit. I bought one before but, did not have any issue.
Old Sep 11, 2018 | 05:02 AM
  #59
Many times they work, many times they dont last as long as the OEM parts and sometimes they dont work.
If the choice is dont fix / Ride because someone cant get or afford the OEM parts, then heck ya, buy the K&L or other repair kits.....I buy um every month ....for me its a huge financial savings over OEM parts for our trainer bikes, even factoring in labor to install another kit a few years later.... The OEM ones don't last either due to crappy high %ethanol gas we get stuck with here and that the bikes sit day after day each week, and for longer stretches in the winter season.
But My personal bikes and the ones that roll though my shop other than trailers..... nothing but OEM parts if available.
Old Apr 17, 2019 | 11:14 AM
  #60
Xbolt22's Avatar
Xbolt22 is on a distinguished road
So... Umm... I heard that your bike won't run very well if you hook the vacuum line to the wrong place. My, uh, friend told me. I, no... he, almost didn't make it to work the other day.
