Clutch hose mounting bracket
Old Aug 8, 2011 | 11:17 AM
wee nor's Avatar
wee nor is on a distinguished road
Hi guys, this may sound silly, after rebuilding the whole bike, I cannot find a suitable mounting bracket in my small parts "still to fit" box to clamp the rubber hose to the lower frame ! Help anyone Cheers.
Old Aug 8, 2011 | 12:04 PM
scottiemann's Avatar
cant find it... zip tie it...
Old Aug 8, 2011 | 12:51 PM
Old Yeller's Avatar
if it's what I'm thinking of, it was a fancy zip tie that was right in the area of the lower rear bolt of the fairing. There were a couple different wires and such bundled together. A standard zip tie should do the trick.
Old Aug 8, 2011 | 01:38 PM
Well I don't have a close up of the hangers hopefully these pics will help.... you might have to download the image and blow it up a little but those are all I have of the clutch line
Also the front hanger is the reusable zip tie that the wiring harness passes through in the front and the rear hanger mounts with the lower fairing bracket.
Old Aug 9, 2011 | 02:23 PM
wee nor's Avatar
Your last picture has jogged my memory........and found the plastic clip. Thanks guys for all your help.
thedeatons
Apr 1, 2015 01:49 PM
joshuatest
Jan 21, 2009 03:30 PM
superchicken99
Nov 5, 2008 07:54 AM
Killemall
Sep 18, 2008 08:42 AM
trinc
Oct 7, 2007 09:12 PM
