Will a 98 vtr clutch cover fit a 2002 vtr?
Old Sep 29, 2010 | 12:30 PM
justinity's Avatar
Über Member
Lightbulb Will a 98 vtr clutch cover fit a 2002 vtr?
I found a clutch cover from a 98 I have a 02 will the year gap have any difference in construction internal that may interfere with the clutch or anything in general?
Old Sep 29, 2010 | 01:01 PM
RickB's Avatar
They are pretty much the same throughout the years except for the lcd gauges, better finned r/r and a few other small changes.
Old Sep 29, 2010 | 01:37 PM
justinity's Avatar
Über Member
better finned r/r?
Old Sep 29, 2010 | 01:43 PM
RWhisen's Avatar
Former Superchicken Owner
R/R finned is 02 and up
Old Sep 29, 2010 | 01:46 PM
saige's Avatar
the boss
the new finned ones are good,but i still did the R6 r/r i think it can take more of a beating.
so did you finally score a clutch cover.
Old Sep 29, 2010 | 02:11 PM
justinity's Avatar
Über Member
What is R/R?
justinity's Avatar
Über Member
Not yet he said some one is in line.. I will keep you posted.
Old Sep 29, 2010 | 02:27 PM
Originally Posted by justinity
What is R/R?
R/R = Regulator / Rectifier
Old Sep 29, 2010 | 02:29 PM
And a late model R1 for $25~35 plus OEM plugs from Eastern beaver ($18) and you have better then OEM set up that looks OEM.
Old Sep 29, 2010 | 02:32 PM
saige's Avatar
the boss
the r/r is called the rectifier,its for the charging system,the old stock one is known to fail.
the newer ones from honda is finned but it looks small to me.
there is a write up on here for the r/r swap,you should see if you have the old one or the finned one.if you have the newer honda finned one,you should be good.
it will bo located on that same spot,but smaller,thats the R6 r/r
Old Sep 29, 2010 | 02:44 PM
RWhisen's Avatar
I sent trinc a PM surrendering my spot in line to you. You should be # 1
Old Sep 29, 2010 | 02:46 PM
saige's Avatar
the boss
i thought you had given that spot up,justinity message trinc and get that cover,i seen how bad you need it lol.
Old Sep 29, 2010 | 08:07 PM
I believe 02 & later added a rubber spigot & hose from the water pump drain hole so coolant that seeped past the impeller seals did not drip down the cover & alarm people; otherwise besides finish type & color, the right side covers are interchangeable. How did this thread diverge to VR/R?
CrickiKaze
Mar 19, 2014 12:06 AM
Crashrat
Oct 11, 2012 08:25 PM
rafbo
Jul 16, 2011 10:24 AM
justinity
Oct 5, 2010 11:54 PM
acarp
Sep 20, 2009 11:14 PM
