What steering damper you guys use?
Old Dec 21, 2005 | 09:31 PM
oicdn's Avatar
oicdn
My front end feels a bit twitcy on lane changes...almost every time I change lanes I cringe just a little at the thought of a tank slapper cause it's so twitchy.
I can't imagine the head angle being steeper than my R6's was, and especially since there's less weight resting on the clip-ons/front end, I wouldn't expect it to be as such....
I know most people think "a damper is a damper is a damper", but what's the common one used on the Hawk? I've looked and saw alot of them required drilling into the frame if they're not top-mount.
So I've been browsing around and wanna see what the general consensus is here. I know on different boards/bikes, there seems to be a general common choice.
Old Dec 21, 2005 | 09:47 PM
superhawk22's Avatar
Was something done on the front end? A stock vtr really shouldn't need a damper for street riding, so check all of your parts for wear. The superhawk has pretty conservative trail.
Old Dec 21, 2005 | 10:31 PM
oicdn's Avatar
oicdn
Re: What steering damper you guys use?
Bike is brand new.....had .4 miles on it when I drove it off the lot. I just don't remember my R6 being as twitchy....maybe it's just from lack of riding in such a long time....
Eitherway, a damper is decent to have.....just wanting to see if anybody else rode a damper...
Old Dec 22, 2005 | 04:07 AM
Galaxieman's Avatar
Galaxieman is an unknown quantity at this point
Scotts:
Old Dec 22, 2005 | 07:50 AM
Loco's Avatar
Loco
Do you think Scott put enough bolts on his damper?
Old Dec 22, 2005 | 09:46 AM
If you can afford it Scotts is a nice one but they all do pretty much the same thing. And they all break if you crash.
Old Dec 22, 2005 | 11:05 AM
NOrrTH's Avatar
I suspect something is not right with your bike.
Of all the stuff I've ever read, people I've talked too and experienced with my own VTR, I've never heard a stock bike referred to as "twitchy". I ride my bike like a maniac, track days and have friends with VTR's that I ride with and only once has someone come close to a tank slapper. He loves to do looooong 100+ mph wheelies down the freeway everytime we go out and came close when he dropped it weird at about 120
Old Dec 22, 2005 | 01:13 PM
Monomaster's Avatar
Monomaster
I have to agree with superhawk22 & Norrth... a VTR in stock configeration should NOT require a damper... If you are suffering with a nervous front end I'd be checking steering head bearings & tyre pressure's first! Have you lowered the forks thru the triple clamps? If so maybe you've gone too far! (I had mine 8mm down & the front was still fine!)
The R6 that I used to own was in a different ballpark nevousness(?!?)-wise
Old Dec 22, 2005 | 01:58 PM
jschmidt's Avatar
jschmidt
Another vote for "look to another source for your problem."
Old Dec 22, 2005 | 02:24 PM
Loco's Avatar
Loco
I would check all the way down to the axle for tightness. That would cause some major twitch.
Old Dec 22, 2005 | 08:19 PM
oicdn's Avatar
oicdn
I haven't adjusted the sag or preload on anything yet...maybe that's the issue...I weigh in at 160....so I'm not a heavy guy....
Old Dec 22, 2005 | 09:00 PM
This is kinda strange, at your weight it should be pretty well set from the factory. There is no way it should feel twitchier, (is that a word?) Than an R6. Does it still have those dunlop 204s on it? If so that should be one of the first things to replace, those tires suck! (IMO) Check evrything to make sure they didn't screw up when they put it together but I think those tires could be the culprit.
Old Dec 22, 2005 | 10:30 PM
jschmidt's Avatar
jschmidt
The tires are not the best, but they are perfectly servicable and not the source of the problem.
Anybody that thinks the stock tires suck, hasn't really experienced the suck factor of, for example, a rock-hard, bias-ply Cheng Shin. It gets a whole lot worse than 204s. The stock tires are actually among the higher end for sport-touring tires. They're just nowhere as good as a good sport tire.
As to the suspension settings, I think they are set up for about a 145 lb person. So they shouldn't be so far off as to be causing your problem.
Tell us more about your problem. Try to be as specific as you can. And while you are waiting for an answer, go check all the front-end bolts for tightness.
Old Dec 22, 2005 | 10:39 PM
OMFNG Cheng shin!!! those tires REALLY SUCK! I had those on my nighthawk when I first got it my god those were pieces of ****. You brought back bad memories with that name! My only point was they really aren't the best tires and are prone to scallop and are a bit pointy. Which can cause a little twitchy feel. You're right it's probably not the cause but could be a cotributing factor. IMO
Old Dec 22, 2005 | 11:08 PM
Alright I thought about it, maybe SUCK was a little strong. Just curious though jshmidt when your's wore out did you replace them with the same kind?
Old Dec 23, 2005 | 03:32 AM
oicdn's Avatar
oicdn
All front end stuff is tight, I think it may just be the lack of riding coupled with cold crappy tires and hard braking on a not so perfect surface.
I went out yesterday and needed to stop faily quick at a redlight AND when traffic for no reason came to a halt on the highway and no nervous front end issues reared thier ugly head.
But I think a damper is in order anyways for all the roads around here are undergoing construction anyhow....that and I don't dig tankslappers
Old Dec 23, 2005 | 04:49 AM
jschmidt's Avatar
jschmidt
Are you kidding? **** no; they suck! (I actually replaced them before they wore out.)
I was just trying to put it in context. I thought your clarification explained their deficiencies pretty well. I had hoped my extensive experience with sucky-tech might do that as well.
FYI, I currently have 208s and they seem to work pretty well. Regarding Dunlops, I read that the new Qualifiers are a top tire. I think most other people like Sportecs or BT014s. I happen to believe you can't buy a bad tire in the top tier these days. But you can still get a Cheng Shin if you want to swing low... :wink:
Old Dec 23, 2005 | 08:39 AM
Yeah, I didn't wait till they were done either.
I have the bto14s and love them but I must admit I'm very curious about the Qualifiers. I've read good things about them, (from Dunlop of course) and i'm curious if they live up to the hype.
Old Dec 23, 2005 | 08:47 AM
EngineNoO9's Avatar
I know people say you shouldn't need one on the street but I wanna get the scotts on mine late spring....
Old Dec 23, 2005 | 08:49 AM
Need and want are two very different things, aren't they?
Old Dec 23, 2005 | 11:17 AM
jschmidt's Avatar
jschmidt
Depending on your disposable income.
Old Dec 23, 2005 | 11:46 AM
Or the size of your credit card debt!
Old Dec 23, 2005 | 01:10 PM
superbling's Avatar
Now their latest sport rubber sold under the Maxxis label is decent. IMO, their Sportmaxx'es for street use are merely OK compared to name brands but if they would drop their prices more then I'd buy another set or two.
FYI, cheng shin is pronounced "cheap skin"!
IIRC, this new owner has a holdover '03. Given that it's shod with 204's that not only are old/stale but they probably still have the preservative on them. He may have just had a "moment or two" with them sliding/slipping on winter streets and liken this to headshake.
Old Dec 23, 2005 | 04:52 PM
Monomaster's Avatar
Monomaster
Nope your were right the first time...they suck the big one!!!!
Do you guys get Shinko brand tyres??? Now they suck..it sould be illegal to put them on your bike, or at least void your warranty! I wouldn't call it rubber, closer to plastic....
Old Dec 23, 2005 | 08:29 PM
Thanks, I've been tempted to try those, glad I didn't burn that cash.
Old Dec 27, 2005 | 06:36 PM
mikecronis's Avatar
mikecronis
Sounds like the shop didn't assemble the bike properly in the front. If you haven't taken it in for your 600 mile service check, I recommend doing so. They also do a valve check and I'd let them know about your issue that's not normal at all! Should cost around $120 and you get an oil change to boot with Honda Pro Synth.
I've never heard of tank slap on a Superhawk whatsoever, even in somewhat bad wheelie landings. Superhawks should never need dampeners.
HRCVTR1000
Jun 18, 2008 07:21 PM
RCVTR
Oct 30, 2007 02:15 PM
HRCVTR1000
Aug 29, 2007 11:55 AM
Hollow Man
Jun 5, 2007 08:26 PM
gssbmm
Jul 8, 2006 08:37 AM
