Water Wetter - Does it work?
Old Sep 30, 2006 | 11:03 AM
gnapoleone's Avatar
gnapoleone is an unknown quantity at this point
Question Water Wetter - Does it work?
I have read that using Water Wetter will bring down cooling temps about 7% ( 7% would equal 14 degrees). This would keep the fan from kicking on during my commute (usually gets to 219-224). Has anyone had success using this type of product.
Old Sep 30, 2006 | 11:26 AM
marmaladedad's Avatar
Hmm?
I use WW on all my bikes. It's great, as long as you don't get into freezing temps. Our bikes still run hot, though. I don't believe the 7% claim, but there is a noticeable drop.
Just be sure to flush the system a few times.
Old Sep 30, 2006 | 03:30 PM
jschmidt's Avatar
jschmidt
It's pointless to solve a problem -- in this case undercooling -- unless you have it. The fan comes on at 221, but that's not an indication of a problem.
Old Sep 30, 2006 | 04:51 PM
so there's such a thing as a VTR that doesn't have an undercooling problem? interesting......
Old Sep 30, 2006 | 05:17 PM
jschmidt's Avatar
jschmidt
Mine cools fine. His does too.
Old Sep 30, 2006 | 05:33 PM
Randman's Avatar
Moderate-whore
I have the stuff, and I haven't used it yet, heard that it is not good for the bike....dunno....I may throw it in next summer, don't think I will need it this year....
Old Sep 30, 2006 | 05:56 PM
lrrs195's Avatar
swinging member
lrrs195 is on a distinguished road
water wetter
I`ve been using it for years in the race bike.I figure if its good enough for a SV thats being flogged on a racetrack its good enough for the superhawk on the street. As was stated above beware of temps below freezing.
Old Sep 30, 2006 | 09:47 PM
I use WW and distilled water on both the 1000RR and the VTR, though both have been to the track, and it was used for that reason. Now that I'm up North with an unheated garage and potential temps below 0°F I will be draining and going to Prestone Long Life (orange stuff) which is silicate free and safe for our water pumps and mechanical seals. If you're wondering, you can still use Water Wetter without draining the antifreeze. I don't think it changes the efficiency of the stuff. The only reason folks use it for the track is because they have to have some kind of coolant that does not have ethylene glycol or similar and the Water Wetter provides increased heat transfer as well as lubrication to the pump.
Old Oct 1, 2006 | 05:23 AM
Randman's Avatar
Moderate-whore
Red face
I willhave to get some ofthat for the winter.
Old Oct 1, 2006 | 08:44 AM
gnapoleone's Avatar
Thanks for the info, I will probably wait until next year. I know the fan comming on is not an indication of a heating issue but I do not like to hear it.
Old Oct 1, 2006 | 12:20 PM
"I know the fan comming on is not an indication of a heating issue but I do not like to hear it."....bingo!!!
When I am riding on a congested freeway or boulevard at say, 50 mph, and the temperature keeps coming up to the point that the fan comes on, I consider that a problem. I have owned other bikes in the past and have spoken to other bikers (non-VTR guys, you know, the guys with the bikes whose rads are actually perpendicular to the wind) and they do not run into this situation even though most bikes are in a higher state of tune. Granted this happens only on warmer (read: muggy) days but I still can't see it being good for the engine. Also, even at normal temps, the bike does not like low-speed riding. While the the side mounted rads has its benefits (narrowness), it also makes for an arrangement that requires decent speed in order to create the necesary air pressure conditions to force the air through the rads. So maybe I am worrying over nothing, but I gladly spend the few dollars needed on WW to help alleviate/reduce this problem. If some of you are ok with your fan coming on in these conditions, well, more power to you Long live free countries
Old Oct 1, 2006 | 06:21 PM
RedHotFireStorm's Avatar
RedHotFireStorm is on a distinguished road
**** ! I just put a paragraph full of reply, and found out I was not logged-in and got flushed....
In a nut shell: I live in the same city as you and I do not have the same symptoms as your bike. My bone stocker will run without the fan until I have stopped for a bit, or in stop and go traffic. Any resonable amount of fwd movement will keep the fan off.
Perhaps you are running lean jetting ? (this is pure speculation, but have you considered this ?) Was it the same before your mods ?
Do any other readers of this thread have to deal with this type of heating issues since installation of pipes / jetting ?
Old Oct 1, 2006 | 08:02 PM
my bike was jetted on the dyno (after mods) and runs perfect. It has been running this way (in terms of heat) from day one (when stock too) and I spoke to my dealer about it who confirmed that VTR's run hot. While not alarming (fan works fine, ...), I can't see it being especially good for the engine for the temp to go up and having the fan kick in. Heat management is also the one of the reasons I have heat wrapped my exhaust (from the manifold right up to the Y on both cylinders, also to keep the shock cooler, and to keep the heat in the pipes for better exhaust flow). Somehow the idea of a hot exhaust pipe heating up the oil in the sump doesn't (especially in slow riding or when stopped at a light) doesn't lead me to believe that it is doing the engine any favours (heat = premature thermal breakdown of oil = reduced lubrication). I realize I am probably "overreacting" according to some, but I like to take care of my stuff and would rather put the odds in my favour.
Old Oct 1, 2006 | 10:26 PM
2Phaast's Avatar
2Phaast is an unknown quantity at this point
Just a thought for anyone thinking of using WW in a brand new engine.... If you significantly reduce the operating temp, in what ever manner, then you could ultimately experience the rings not seating and the resulting high oil comsumption. This can only be resolved thru engine disassembly, fly cut the cylinders again, and install new rings.... Spoken from experience.... On a new engine a few years ago, I installed a significantly larger oil cooler, larger sump, WW, thicker core radiator, and thermostat set for 185 compared to the normal 210..... Engine ran super cool just as expected, but never "broke in"....
Old Oct 1, 2006 | 10:40 PM
Texassuperhawk's Avatar
Texassuperhawk
Has anyone considered makeing a "scoop" for the radiators, sort of like they make for the 400ex quad? Something that would force air through the rads.
Old Oct 2, 2006 | 12:34 AM
How about something like the Moriwaki fins for the RC51?
Old Oct 2, 2006 | 04:11 AM
denmah's Avatar
denmah
manual fan switches are cheap to install.
Old Oct 2, 2006 | 05:43 AM
turboblue's Avatar
turboblue is on a distinguished road
interesting little bit of knowledge about water wetter. it's not just a catchy name, it actually makes water wetter in a way. basically all it does is reduce the surface tension of water without damaging the cooling system and without foaming. allows the water to penetrate deeper into the rough castings inside a factory produced sand casted engine block. the more surface area a given amount of fluid can touch to transfer heat the better the cooling efficency of the bike. kinda neat.
Old Oct 2, 2006 | 06:50 AM
interesting...thanks for the info I always wondered just how it worked
cheers
Mikstr
Old Oct 2, 2006 | 08:03 AM
jschmidt's Avatar
jschmidt
They have a scoop, in front. It pushes air out the sides. Putting a scoop there would make cooling worse by trapping airflow.
Old Oct 2, 2006 | 12:45 PM
Texassuperhawk
I forgot to mention my superhawk is naked.(he he)
Old Oct 2, 2006 | 01:52 PM
turboblue's Avatar
if you wanted to put scoops on the radiators since it is naked it would be good. it would also be wise to reverse the polarity on the radiator fan so it pulls instead of pushes.
Old Oct 2, 2006 | 02:07 PM
Radiaoktiv's Avatar
Radiaoktiv is on a distinguished road
isnt the point to push heat away from the motor?
not pull it in, towards the motor
Old Oct 2, 2006 | 02:14 PM
turboblue's Avatar
well it can go both ways. yes blowing the fan towards the motor will create more warm air flowing towards the engine. however, cooling efficency isn't going to be comprimised quite as bad as if the bike had a fairing on it. most of the cooling is handled by the liquid cooling system. in a car every radiator i have seen to date dumps fresh hot air on the engine. i say if you are going to put dirt bike style scoops on the exterior of the radiators it would only be common process to make the fan flow air the direction it is being forced in. plus if the radiator has ready acces to cooler ambient air as opposed to drawing air across a 1000 degree exhaust tube i would pick the ambient air any day of the week.
Old Oct 2, 2006 | 02:21 PM
Radiaoktiv's Avatar
youd also be dumping hot air right into the oil cooler
IMHO...if any scoop is to be mounted, it should be to pull air away from the radiator
Old Oct 2, 2006 | 02:31 PM
turboblue's Avatar
ideally the oil cooler should never be mounted where it has to share air flow with the radiator. if you were to put a scoop on a radiator that uses a vacuum force to draw air from it it will be mostly pointless at anything below highway speeds. ram air is the way to go and i know there is no room for a scoop on the back side of the radiator so that would complicate things. on any liquid cooled internal combustion engine both oil and liquid cooling are important. however, if the engine were merely air cooled with an oil cooler it would be imparitive for the oil cooler to recieve the coolest air possible. i would say this is a trial and error situation that needs to be monitored with the coolant gauge.
Old Oct 2, 2006 | 03:07 PM
Radiaoktiv's Avatar
i agree, well mostly
i think radiator scoops, at least on our beloved Hawk, is near to pointless. as you said, the force needed to make a difference in cooling is only apparent at highway speeds...where cooling is almost never a problem.
however, when the cycle is at low speeds or stopped (when cooling becomes an issue), if the fans are pulling in you're essentially cycling the heat that the cooling system is trying to expel, back in front of the intake/engine.
maybe im just having trouble seeing the benefit
Old Oct 2, 2006 | 03:15 PM
turboblue's Avatar
well i see your point but at the same time a liquid cooled engine isn't really affected by outside temperatures like an air cooled engine is. since the external castings of a liquid cooled engine are smooth it is much more difficult for air temperature to play a deciding factor in cooling. if hot air from a radiator was such a deciding factor in cooling systems i would think every car on the planet would have the air from the radiator directed away from the engine instead of having a fan blow it directly on it.
Old Oct 2, 2006 | 03:27 PM
Radiaoktiv's Avatar
not to debunk your theory, because i do agree in the differences in air vs liquid cooled
but i do know of several guys who run push fans in thier cars. (they are, however, by no means stock.)
i guess in my mind, it only makes sense to expel the heat away from the machine you're trying to cool
Old Oct 2, 2006 | 03:34 PM
turboblue's Avatar
well i have a 450 wheel horsepower 240sx nissan that i built myself sitting in my garage about 10 feet from me. when i wired my radiator fan backwards by mistake (blowing away from the engine) it boiled over. i'm not trying to start anything but i would dare not go on a forum and be a newbie and start posting ideas if i didn't have past experience to back me up.
