twin headlight system for hawk
Old Nov 23, 2008 | 05:50 AM
chevy's Avatar
chevy is on a distinguished road
has anyone attempted to replace the single stock headlight system, for a double like on current street bikes.
If Not....is it Possible?
Old Nov 23, 2008 | 06:26 AM
Yep... It's been done... One way is to swap the entire front end plastics... Apparently the CBR600 from some years can be made to fit... Also the RC-51 plastics can be fitted with some work...
The other is to swap out the stock headlight for a mounting for two smaller projector lights... Here is one example... http://cgi.ebay.com/ebaymotors/TWIN-...91110009r26902
Then there is the option to go with race plastics and make a totaly custom job your self...
Old Nov 23, 2008 | 10:06 AM
chevy's Avatar
Tweety
I didn't think it was possible, but with a group of guy's here at SH Forum any things possible.
I love the twin look.......really steps up the bike!
Old Nov 23, 2008 | 10:34 AM
There was a direct replacement for the single headlight that turned it into a double unit from Wild Hair Accessories. Pretty ugly and dated IMO...
Old Nov 23, 2008 | 10:46 AM
chevy's Avatar
i like the yellow, this clearly gives me a better view!
kinda makes you think about what you really wanna do from this point, now seeing it on the bike.
Thanks Inderocker!
Old Nov 23, 2008 | 10:51 AM
I like this better...
http://www.tweety.se/gallery/HID%20B...g/PICT1695.jpg
Old Nov 23, 2008 | 11:38 AM
Truckinduc's Avatar
ANYTHING IS POSSIBLE
Old Nov 23, 2008 | 02:10 PM
LineArrayNut's Avatar
I could ride in
divide one by zero then...
Old Nov 23, 2008 | 04:28 PM
Reason's Avatar
Greenmeansgo!
Looks good, Tweety, but it needs a little... something...
There are some cool dual kits for streetfighters here, not sure how hard it would be to adapt, or if it'd be worth it. I like the Hesa Headlight fire myself, that vertical stack is nice.
http://www.streetfightersinc.com/Headlightkits.htm
Old Nov 23, 2008 | 09:25 PM
Truckinduc's Avatar
ok,
anything on a bike
Old Nov 24, 2008 | 05:01 AM
The girlies I like but the halo is a definete no-no... My bike is a no bling zone... It goes like crazy in the corners instead... It's so fun to do circles around the squids on blinged out bikes...
Altough if I do find a suitable shroud/ring in chrome or otherwise I will use that to cover the irregular shape of the projector itself... I like the clean black, but the way it looks is mostly to have it sealed up... No light leaking in the wrong places...
Old Nov 24, 2008 | 06:38 AM
Byrdman's Avatar
Super Byrd
ok,
anything on a bike
very nice
Old Nov 24, 2008 | 07:46 AM
I could ride in
well done truck, well done!
ok,
anything on a bike
Old Nov 24, 2008 | 08:54 AM
I could ride in
They went to the trouble to make it look like a HID projector... then put incandescent bulbs in it... doesn't make much sense to me...
Old Nov 24, 2008 | 09:52 AM
Not to me neither... Altough the incandescent bulbs in a projector is a tad better than with an open reflector... They still suck in comparasion......
Old Nov 24, 2008 | 10:45 AM
Erik S.'s Avatar
Tweety, is your HID a Low/High, or just low beam?
Old Nov 24, 2008 | 03:02 PM
Low/High... solenoid... It's from a nissan G35...
BTW look here for a gallery... Text is in Swedish so it might not be usefull... But there are a few more snaps...
Basicly what it says about the HID... The rear two bolts used to adjust the aim is functional... The projector is mounted on a "frame" of 2 mm aluminium sheet that is brushed matte and painted black... and uses the 3 internal mount points... one fixed joint and two bolts...
Iteration 2 will be prettier... I have figured out how to hide the two hex bolts from view and in that process I'm going to tighten up the gap in a few places around the projector...
Old Nov 24, 2008 | 05:46 PM
Truckinduc's Avatar
here are the projectors i picked up for 60 bucks, i plan on going HID with them but i have to test the housings first to see if they can take the extra heat.
Old Nov 24, 2008 | 05:48 PM
Truckinduc's Avatar
Old Nov 24, 2008 | 08:10 PM
chevy's Avatar
CruxGNZ
Apr 30, 2015 09:11 PM
hondavtr1000sp2
May 12, 2014 01:19 AM
ozzie9962
Apr 11, 2009 10:49 AM
HRCVTR1000
Oct 11, 2007 07:06 PM
EngineNoO9
Nov 20, 2006 05:08 PM
