Too many CCA's on battery?
Old Mar 11, 2010 | 01:59 PM
psyclown's Avatar
psyclown is on a distinguished road
I have a 2000 Buell Cyclone that uses a battery with 270 CCA's. I was wondering if anyone thought that this could do any damage in a SH that I believe only needs 210 CCA's.
If so, hurry and let me know before its too late....I'm impatient
Old Mar 11, 2010 | 02:08 PM
nope. It won't hurt it, assuming it fits.
Old Mar 11, 2010 | 04:24 PM
bjorn toulouse's Avatar
Destructive Tester
What does CCA mean?
Cold Cranking Amps is a rating used in the battery industry to define a battery's ability to start an engine in cold temperatures. The rating is the number of amps a new, fully charged battery can deliver at 0° Farenheit for 30 seconds, while maintaining a voltage of at least 7.2 volts, for a 12 volt battery. The higher the CCA rating, the greater the starting power of the battery.
I borrowed the above from: http://www.autobatteries.com/faq/index.asp
12 volts is 12 volts.
Rex
Old Mar 11, 2010 | 05:06 PM
Rex
Yep and there really is no such thing as too much CCA's.....
Old Mar 11, 2010 | 06:44 PM
The old rating system used Amp Hours. CCA as a rating started in the early '80s for car batteries. The 2 are related, but AH is easier to understand.
A 24 Amp Hour battery could put out 24 amps for 1 hour, or 1 amp for 24 hours, or 2 amps for 12 hours, etc.
When a battery is load tested, it should be loaded for 15 seconds @ 1/2 the CCA. If the battery is rated in Amp Hours it is loaded for 15 seconds @ 3 times the AH rating. 9.6V or more at the end of the 15 sec load indicates the battery is okay.
Therefore, for purposes of testing, Amp Hours x 6 = CCA.
Old Mar 11, 2010 | 06:53 PM
psyclown's Avatar
Thanks for the input. All I expected was a yes or no and I actually learned something
Old Mar 11, 2010 | 07:15 PM
Just keep the voltage at 12, and you're good.
Old Mar 12, 2010 | 07:05 AM
NCDave's Avatar
does it fit in the battery box on the SH?
Old Mar 15, 2010 | 12:48 PM
NCDave's Avatar
so....any news on the install? I'm curious to know if the battery fit.....
dpenix76
Sep 7, 2007 09:12 PM
supertwinSH
Aug 22, 2007 06:03 AM
grampi
Nov 21, 2006 07:49 AM
EngineNoO9
Sep 2, 2006 10:10 PM
NOrrTH
Nov 25, 2005 09:59 AM
