Tire Watch...constant pressure/temp. monitoring!
Has anyone heard of this system or used it? Its expensive, but seems like a great idea! of course, a $10 gauge would work too...;)
http://www.tire-watch.com/index.php?...=28&Itemid=118 |
I like the idea, but its just as easy for me to check them weekly. My tires are filled with nitrogen. Since I quit using air, my pressures remain constant and do not leak (yet):cool:
300 Clams! F-that!
(Post 199190)
Oh don't get me started on nitrogen....:wtf2: |
Fire it up! Is there something wrong with nitrogen? I run Nitrogen in all my vehicles. Now I think I'm gonna use it in the hawks tires. I don't know why I haven't all along!
Yep, I too would like to know what your aurgument is on using nitrogen.
There's nothing wrong with nitrogen.
Just no advantages either. :evillaugh: |
The one advantage it has is that with the right mix, you have less variation in tire pressure with temperature... Not myth... fact... But other than that it's the same...
And the price you pay to get it in there is insane... |
Normal air is 79% nitrogen, 20% oxygen and 1% misc (mostly argon)..
So if you keep inflating your tires, and mostly the oxygen leaks out over time.. eventually it will be nitrogen filled with just using normal air!! lol (really, the differences are not measurable unless you only check your tire pressure once a year) |
most paintballers use nitrogen in their tanks so their pressure doesn't fluctuate
I have been told, basically, nitrogen molecules are larger than oxygen's and leak at a slower and more consistent rate. We still need to check our pressure regularly of course, but it just helps with gas mileage and tire wear between checks!
oh, and its not effected by ambient air temps either!
Actually there are many more advantages to using nitrogen. I have been in aviation maintenance for over 25 years. The use of nitrogen is used in shocks, struts, accumulaters, tires, etc... It will hold a more constant pressure under hot or cold conditions. The molecules are larger and do not leak past seals, o-rings and inner tubes like air does. Nitrogen is dry, using air also induces moisture into anything you put it in, even with a water seperator.
Soo, since I keep nitrogen bottles at my hangar for aviation related work, its all free to me :D and to any of my friends who need or want some :cheers: I see alot of planes that do more sitting than flying. Those who use air are always adding and the ones with nitrogen do not unless they have a forien object or hole in the tire. Do what you want, but i'll continue to use nitrogen. |
(Post 199181)
(Post 199271)
It will hold a more constant pressure under hot or cold conditions...
Nitrogen is dry, using air also induces moisture into anything you put it in, even with a water seperator. The crap a tire shop is filling your tires with isn't pure or dry nitrogen, maybe 90% nitrogen. Maybe not much more than the nitrogen you're breathing now. They're also not purging the air out of your tires beforehand. Also as the oxygen leaks out of your tires faster, the % of nitrogen will increase. It does perform better in some ways, like slower leak rates, but most of the benefits are exaggerated or invented entirely. One of those benefits is easy and safe portability. It can be liquified relatively easy at room temperature (~1500psi), so a lot of it can be stored in a very small space compared to the same quantity of air. And as a liquid which is basically not compressible, it's not going to explode like an atomic bomb if the bottle is knocked over. |
Whatever you need to do to keep your tires inflated to the proper specs is the smartest move. Debating nitrogen or air is a distraction, if you don't invest in a good pressure gauge that doesn't piss you off every time you try to wedge it in past the brake rotors. Also, find an air chuck that gets into both front and rear wheels, without trying to tear out your valve stems or remodel your knuckles in the process . Like any other regular maintenance, having the right tools on hand makes it so much easier to stay up on tire pressure.
If you find yourself putting off checking tire pressures every couple weeks , or avoiding topping up to optimum pressure because it's a pain in the arse, you are very likely going to wear out your tires prematurely, regardless of what gas you chose fill them with. Tire prices keep going up and UP again, so paying attention to your tire pressures on the reg is smart money. |
One word: angled valve stems.
I fill my tires with a precise mixture of 78.09% nitrogen, 20.95% oxygen, 0.93% argon, 0.039% carbon dioxide, and small amounts of other gases. Only troglodytes use common air these days. |
going all the way back to the original post from 2009, that web site sucks
i tried a cheap tpms a few years ago. they were valve stem caps that contained a sensor and transmitter. they were garbage. they let air out themselves, thus increasing my required effort to maintain air pressure. |
Yeah, but they let you know about it, right?
Originally Posted by VTR1000F
(Post 394322)
Amazing coincidence - I use exactly the same stuff in my tires, but I bet I have you beat - I get mine for FREE! |
I have a special tank in my garage in which I mix and compress my own, so...
(Post 394330)
Light a match!
Originally Posted by Byrdman
(Post 199267)
Also the tanks used for Nitrogen last longer and also hold a considerable amount more pressure then the oxygen Tanks so there is less time at the refill station. |
And, don't forget the troglodyte thing.
I use Nitrogen because it's better......... it's better because the tank is closer to the bike most days than the air hose which contains 79% nitrogen....
either way a pricy liquid filled 1/2 lb incremental pressure gauge is used to set tire pressures cold....and that I think is more important than the gas used. |
78.09% Nitrogen.
(Post 394382)
78.09% Nitrogen.
you guys are full of methane
