Sputtering on deceleration... normal?
Old Nov 9, 2009 | 02:13 PM
AngryOlaf's Avatar
Hi all,
So I've had my SH about a month and a half now... and after sorting out a few issues. I love it!
The only issue I seem to have now, and it may actually be a non-issue, is the way the bike sputters when it decelerates. How much should the bike do this, and should I even be concerned?
- Mike
Old Nov 9, 2009 | 02:16 PM
drew_c14's Avatar
Is it a sputter or a backfire? If your pair has been removed check all the places that you blocked off the lines and make sure air isn't getting in.
Just_Nick's Avatar
Who are you?
Do you mean backfiring? Sounds like gurgling? Normal, especially with slip-ons.
Old Nov 9, 2009 | 02:21 PM
AngryOlaf's Avatar
No backfiring... just an irregular gurgling. it gets stronger with engine braking.
The bike is completely stock and still has the PAIR system in place.
I figured it was just part of the v-twin sound... my buddies Ducati 900ss makes some similar noise. Just thought I would ask to be sure.
Old Nov 9, 2009 | 02:29 PM
Just_Nick's Avatar
Who are you?
That gurgling sound is pretty normal if you still have the PAIR stuff.
Old Nov 9, 2009 | 04:51 PM
AngryOlaf's Avatar
BTW... thanks for the quick replies all!
Old Nov 9, 2009 | 05:15 PM
Kendrick's Avatar
The Hypno-Toad
Yeah, they do that. It's half the fun. Make sure you let it loose in front of an out door cafe, and then pull a wheelie! Yeah, my neigbors hate me...
Old Nov 10, 2009 | 05:55 AM
Disconnect the PAIR stuff and if it still does it, you need to richen the mixture screws a bit.
Old Nov 12, 2009 | 09:29 PM
avramd's Avatar
avramd is on a distinguished road
PAIR Valve purpose
This is actually precisely the purpose of the PAIR system. PAIR stands for "Pulse secondary AIR injector". I believe the PAIR-ectomy thread explains this. In short, those sounds are pulses of air micro-exploding in your exhaust
system in order to burn off unused fuel that gets sucked through the engine on deceleration, especially engine braking. The fuel is there because the vacuum is disproportionately strong in relation to the throttle position, and as a result, the carbs provide more fuel/air mixture than is optimal for the situation, so not all of it gets combusted in the cylinders.
I think I got that right...
This is one of the many reasons nobody uses carburetors any more. As elegant as some of them are, they are a total hack compared to modern fuel injection. Carbs are all about coercing the laws of physics into doing something pretty close to what we wish would happen as often as we can get away with. FI is all about deterministically making exactly what you want to happen directly happen at all times.
I would be *very* interested in riding a FI'd hawk (ok storm) someday.
dutchdude
Apr 5, 2015 04:57 PM
ChillyWaa
Jan 9, 2014 08:39 AM
01SuperChicken
Dec 3, 2008 09:54 AM
SuperHawkSF
Nov 26, 2007 06:21 PM
matix
Oct 6, 2005 06:57 PM
