Sproket/chain replaced
Old Nov 8, 2007 | 09:55 AM
thegreep's Avatar
thegreep
I finally changed my sprockets and chain, went down 1 on the front and up 2 on the back. Holy crap! what a difference! The front end feels light as a feather under moderate acceleration.
Old Nov 8, 2007 | 10:01 AM
drew_c14's Avatar
That's a fairly drastic change. Hope you like it!
Old Nov 8, 2007 | 10:37 AM
Thumper's Avatar
Doesn't that work out to like 5 teeth larger in the back.....I bet she is a wheelie monster now.
Old Nov 8, 2007 | 11:11 AM
RickB's Avatar
That sure will wake it up...
enjoy but be careful....
Old Nov 8, 2007 | 01:39 PM
Blue Ridge Boy's Avatar
At what point does the chain need to be lengthened because of how many teeth there are on the rear sprocket?
...I don't mean to thread jack...just didn't want to start a whole new thread for this question. Thnx
Old Nov 8, 2007 | 01:42 PM
drew_c14's Avatar
I could be wrong but I think it's pretty much based on chain tension. If you still have enough room for adjustment of the back tire to get the tension right then it's ok. If not then you have to add or take away links as called for.
Old Nov 8, 2007 | 01:45 PM
thegreep's Avatar
thegreep
If you are changing sprockets you should be changing the chain too.
Old Nov 8, 2007 | 05:14 PM
Syclone's Avatar
Boosted
Lengthened not changed...
Old Nov 8, 2007 | 06:39 PM
happytrack44's Avatar
WERA #44
up 2 down 1?
Ain't that a 15/43 combo and the standard upgrade? That's what I have and have never ridden it otherwise. Stock must be kinda mellow.
Old Nov 8, 2007 | 06:43 PM
WERA #44
links
102 links (stock) works well with the 15/43, shortens the wheelbase just 1 tooth, but leaves enough adjustability to get your slack right.
Old Nov 8, 2007 | 10:03 PM
SuperHawkins's Avatar
I went 15/44 and bought a longer open chain and pressed it together with it run around all the pulleys and held taut to about the minimum tension length on the swingarm and marked accordingly.... I went 520 conversion though....if you look on ebay you can get a hardened ft steel sprocket, RK 520 chain, and rear alum. sprocket your choice of teeth for like 130 or so....was the best deal for me. Though the back sprocket only lasts a couple k miles til its worn out.
Ive got a hair-drastic more gear than you but very close, and yeah its a huge step up! All my friends that I let get on my bike, which is very few...I tell em, SMOOTH throttle...and don't even try first. Ever.
Next thing I see my friend doing power-on wheelies down the road on my bike. lol
Old Nov 8, 2007 | 11:02 PM
Syclone's Avatar
Boosted
That's what I've heard, and what I plan to do this winter...
Old Nov 9, 2007 | 04:49 AM
drew_c14's Avatar
That seems like a lot to me. I think 16/44 is more reasonable.
Old Nov 9, 2007 | 07:33 AM
HRCA#1's Avatar
My 2cents on gearing. I was taught years ago to use the tallest counteshaft sproket I could fit and change the rear gearing to suit. The rule of thumb being 3T on the rear equalled one on the front. Unless your goal is to rev the engine quicker or do wheelies easier in 3rd gear, there is no need to lower the front sprocket. If you want to improve driveabity out of corners leave the front alone and raise the rear 2-3T. I would also say that switching to 520 chain and sprockets on this bike with this kind of torque doesn't really make much sense unless you want to burn up sprockets again too much torque.
Old Nov 9, 2007 | 08:01 AM
Syclone's Avatar
Boosted
How many teeth can you go up in the back without needing a longer chain?
Old Nov 9, 2007 | 08:08 PM
I think what he means by the standard set or whatever....is the 520 and sprocket sets that are all over ebay for this bike, all come standard as 15-43 with a 520 xring, and then you get options to fug with the rear teeth, chain color, etc....think the front tooth count is locked in but not sure.
Old Nov 12, 2007 | 12:36 PM
thegreep's Avatar
thegreep
After riding a bit I would have to agree, the step down in the front sproket made the bike way too low, it was like I lost 6th gear all together. I'll be changing the front back to the stock sprocket size as soon as I can. . .That will leave me with 2 teeth up in the back, so it will still be slightly lower than stock.
Old Nov 12, 2007 | 01:01 PM
gssbmm's Avatar
gssbmm
I run a 15/43 and 15/45 with the same lenth chain and have enough room for a 47. I set up the chain to be at full lenth with the 43 on and as I put the bigger sprokets on the wheel just moves closer on the swingarm. 5.25 notches out with the 45 and 3 on the 43 if you look at the nothces on the chain ajuster on the swing arm. it works for my track set up. btw imo. a 45 sproket sucks on the street I wouldn't recommend it if your ever going to get on the freeway
Old Nov 12, 2007 | 01:15 PM
HRCA#1's Avatar
Most Honda's have always been slightly under geared for as long as I've been riding them and that goes back to the late 60's..just the fact that top gear is under 1 to 1 making a slight overdrive attests to that. My experience is that 2 or 3 up in the rear is about the optimum for good tractability on the street and surprisingly very often on the track. Even if you change the primary gearing or make major changes to the power output or more importantly how high you can rev it the basic rule still applies.
Old Nov 12, 2007 | 04:49 PM
Slim's Avatar
Slim is on a distinguished road
It depends.
If you have an old chain and sprockets then you should be chainging/replacing the entire set up.
If you have a relatively new set up then it might not be necessary. If you only put 200 kms on the set up, and didn't ride the crap out of it, and don't like it and want to change it then you can probably get away with only changing a sprockets and leaving the existing chain.
Again, it depends. How much room is available with the current set up? You can't always go by what works on someone else's bike because of wear in various parts of the drivetrain and suspension.
Old Nov 12, 2007 | 04:57 PM
Slim's Avatar
Depends on who you talk to. The standard, I find, depends on riders' standards.
What I mean is ..... here's a few examples;
If I talk to a more mellow rider then I usually hear either -1 in the front OR +2 in the back. If I talk to a more agressive rider then I hear "dude, you SO totally gotta go -1 and +2. It ROCKS!". If I talk to a racer then before I can finish what i'm asking I get "what bike and what track?".
I think the biggest reason that the -1/+2 swap is so typical is because there's lots of riders out there that want their gutless I4 600 to run like a 1000. That and the magazine articles that show what you can drop in a 1/4 mile run are also fuel for the fire.
Don't get me wrong, i'm not knocking it, as gear changes can, and do, change a bike and also continue to provide the best bang for the buck. I just think that most people succumb to marketing hype way too easily and wind up doing something they later regret ..... for little to no reason at all. I hate to point a finger, but ..... thegreep is changing back, with good reason. (that didn't take long lol)
Old Nov 12, 2007 | 07:40 PM
Hotbrakes's Avatar
I just put the 15/43 520 conversion on mine and I love it. I'm not crazy about the 520 chain cause of the wear factor but the ratio rips. Last Sunday I hit balance point in 5th off a small crest and 4th gear standups are effortless. Another problem is I have no idea how fast I am going. Where and how much is a speedo healer?
Old Nov 12, 2007 | 09:48 PM
LotusLand's Avatar
Old Guy
LotusLand is on a distinguished road
Hey HotBrakes -
Where did you get your kit. I've been on the web, including eBay (and I've searched the forums) but can only find stock.
Old Nov 13, 2007 | 07:34 AM
HRCA#1's Avatar
I think Slim summed it up perfectly!! I also think Hotbrakes is the classic example of why most riders opt for the lower ratio..so they can do 4th gear wheelies!!
Old Nov 13, 2007 | 01:06 PM
Hotbrakes's Avatar
Lotus Land...I ordered mine off eBay for about $160 shipped. If you search "superhawk" you should find it listed a couple of times. Sumofallparts is the store I got it from.
Old Mar 10, 2008 | 07:24 AM
thegreep's Avatar
thegreep
As an update to this thread, called up sum of all parts over the winter and they were happy to sell me the 16 tooth front sprocket. This did in fact put the bike where I want it to be gearing wise. So, Now total I'm down 2 in the back w/520 chain. It pulls better than stock, but not crazy like it was.
lukenukem47
Aug 29, 2010 10:47 PM
Ludicrous_Speed
Jan 20, 2010 09:01 PM
Felton1
Jun 23, 2009 03:37 PM
Otto Man
Jun 18, 2008 09:18 PM
supertwinSH
Oct 30, 2007 09:38 AM
