so what exactly does valve noise sound like...
Old Aug 2, 2006 | 03:02 PM
EngineNoO9's Avatar
went for a brief ride today in the heat and I was hearing some noise and couldn't really say what it was. it would come and go but would happen really when my idle would drop a little... maybe I should take it to a shop to get checked out...
Old Aug 2, 2006 | 05:36 PM
Speed_Demon's Avatar
Valve noise is normal. As clearances wear/tighten they will actually get quieter. What makes noise is the cam chain. Its an inconsistent slapping sound.
Old Aug 2, 2006 | 06:18 PM
EngineNoO9's Avatar
yeah but see I just changed my cct's 1500 miles ago and to me it didn't sound like cam chain noise...
Old Aug 2, 2006 | 07:35 PM
What oil are you using? These V-twins like the heavier 15W-50 to keep them happy and quiet. It's better oil anyway, at least in the Mobil 1 variety. Go to 1000RR.net and do a search of posts from a guy with the screen name of ScootR. He tests oil for a living. Good enlightening stuff.
Old Aug 2, 2006 | 07:41 PM
EngineNoO9's Avatar
just put in 10w-40 repsol synthetic... had been using 10w-40 honda oil
Old Aug 2, 2006 | 07:42 PM
marmaladedad's Avatar
Hmm?
You like the synth more?
Old Aug 2, 2006 | 07:48 PM
EngineNoO9's Avatar
it seems to help with shifting some... not sure about any heat or smoothness it adds... wondering if I do need to go with some like a 15w...
I'm assuming using this isn't gonna cause issues other then it being a little more noisy right? or should I really change it out for something heavier? I have been using 10w ever since I've owned it. 12k to now 21.5k
Old Aug 2, 2006 | 08:05 PM
superbling's Avatar
Yup, he was a prolific poster on VFRd also especially when it came to oil threads. He lives right up the road from me (in Texas terms anyway). He left VFRd under the cover of darkness after getting busted for naming names as in oil companies once too many.
Is he still on 1000rr.net? Even after totalling that bike? Supposedly went MVAgusta and haven't heard from him since.
Old Aug 2, 2006 | 08:19 PM
He posts every now and then. Didn't know he totaled his RR though. Since the reincarnation of my VTR, I've mostly been focusing on this forum. I browse the Suspension threads on a regular basis though.
No9, I'd think that changing even brands of oil can change the way a bike sounds and shifts. It might not hurt it, but you might not like it either. I wouldn't waste $20 in oil but try the M1 next time. I guarantee you'll like it!
Old Aug 2, 2006 | 08:23 PM
EngineNoO9's Avatar
regular mobil 1 synthetic or is it a special motorcycle blend?
Old Aug 3, 2006 | 11:08 PM
miken996's Avatar
miken996
so I am guessing its when the bike is in neutral correct? if so you can prob around the engine case with a long screwdriver and your ear on the other end it can help with pinpointing the noise if its coming from the top end or bottom end its not ideal but can work. when you idle drops without additional rpms the load on your engine increases and can cause some nastey noises if it drops two much so it sound to me like you may be all right just bump your idle up a bit mine idles 1100-1200 bounces + - a few here and their. how many miles on your rig!!
Old Aug 3, 2006 | 11:30 PM
No9,
Just the regular synthetic stuff. Same thing I put in my cars too. Hard to find up north in the heavier weight at Wally World, but Advance Auto has it. I really need to order it by the drum directly from Mobil. It'd be cheaper that way, ya think?
Old Aug 4, 2006 | 12:15 AM
EngineNoO9's Avatar
yeah I have a ton of that mobil 1 around. normally buy by the case. I'll try that out next time
Old Aug 4, 2006 | 02:25 AM
mikecronis's Avatar
mikecronis
Don't use the Mobil 1 you use for cars or your clutch will burn out. Use Mobil 1 MX4T instead.
Old Aug 4, 2006 | 09:13 AM
That's not true. That is a FALACY. I've been using M1 regular since the first oil change. I now have 40000 miles on the bike and have never had clutch issues. I took the clutch apart at 25k to install the ignition advancer and the cross hatching was still on the plates from the factory. Oh, and I've not had to adjust the valves once.
Old Aug 4, 2006 | 09:17 AM
superhawk22's Avatar
Damn you beat me to it again!!! Oh well +1 on what Greg said.
flyguyeddy
May 29, 2011 08:54 PM
uchi
May 1, 2010 08:26 AM
Kators
Dec 13, 2009 06:13 AM
Gritsngravy
Jul 17, 2009 11:53 AM
Scoutpilot
Oct 3, 2008 09:36 PM
