And so it begins
And so it begins
Here is the start of my project.
Glad Tapatio didn't charge me extra for the giant Black Widow living in the exhaust port.
So far the cylinders look good no ridge on the top, funny thing is the rear CCT (stock Honda) the tip was all smashed over. don't know what that was about.
I will be ordering Mori cams as soon as Bill gets back to me, I need to get the case split to see what bearing is spun, then take it to my engine guy to check for out of round before I purchase HC pistons.
Finally got the cases all split this weekend. Crank connecting rod journal was the culprit.
The journal doesn't feel gouged with a fingernail just scorched.
I need to have it reground and polished.
Anyone know if you have to replace connecting rods in pairs?
I was just thinking about that shouldn't the weight be removed from the middle of the back strap?
What about pistons use the inside edge of the skirts to adjust the weight difference?
With rods if you want to be really picky then you'd match not only the overall rod weight, but you'd check how it's distributed from end-to-end. You do this by having one end of the rod on a solid surface off the scale and the other end on the scale. You do this with each end on each rod with all hardware/bushings in place.
http://www.performanceengines.com/pe...RodBalance.jpg
Im kind of impatient so I put my new cams in today.
I put the bike on the Dyno at Full Throttle Power sports and I was getting 88 at the rear wheel. Torque was unreadable bad RPM connection.
All of the cams are hollow, or you've got a lubrication problem.
Mori cams were made with the factory castings. Fatter lobes=more weight.
I found this airbox mod, but not sure if it'll work or not for what you're doing...Mikstr's mod is less aggressive...
http://www.ablett.jp/bikes/vtr/air_box_lid.htm
Seems a lot of work and money for fewer horsies
http://www.ablett.jp/bikes/vtr/air_box3.htm
